Will this throw the crank balance off??
Old Feb 29, 2004 | 09:11 AM
Maddox's Avatar
Default Will this throw the crank balance off??
I have a h22 longblock, and there is a little stud that comes out the of the crank to hold the flywheel on the crank. I was wondering if I cut that off would it throw the balance off of the crank?
Let me know. Here is some pics of what I am taking about. Thanks Guys.
Old Feb 29, 2004 | 09:30 AM
junbb1's Avatar
Default Re: Will this throw the crank balance off?? (AllMotorCRX161)
why???
Old Feb 29, 2004 | 11:04 AM
simple4012's Avatar
New User
Default Re: Will this throw the crank balance off?? (junbb1)
i hate H-series blocks and i know that is needed on there. You need it for timing marks.
Old Feb 29, 2004 | 11:08 AM
ArinX's Avatar
just wondering did you get your crank rebalanced without that stud?
Old Feb 29, 2004 | 12:34 PM
ranta18's Avatar
Default Re: Will this throw the crank balance off?? (ArinX)
That stud is what locates your flywheel. Your flywheel can only go on 1 way and assures that the timing marks will be ok. DON'T CUT THAT!
Old Feb 29, 2004 | 01:40 PM
GOLDBERG's Avatar
Default Re: Will this throw the crank balance off?? (ranta18)
i swear..some people just dont make sense..why would u want too cut that???
Old Feb 29, 2004 | 01:52 PM
aeolus's Avatar
Default Re: Will this throw the crank balance off?? (GOLDBERG)
im wonderin,did you get an aluminum flywheel with the stud hole being off???
Old Feb 29, 2004 | 05:58 PM
Maddox's Avatar
Im making a adatper plater for a B series tranny to go on a H series block, the H series flywheel is too big in diameter, the H series is 12 inch in diameter and a B series is 11 1/2 in diameter. I have to use all B series parts so it will work. That is why I was asking if I could cut it off, so I could put my B series flywheel on.
Might be better off drilling a hole in my flywheel instead of cutting that pin off.
Modified by AllMotorCRX161 at 4:30 AM 3/1/2004
Old Feb 29, 2004 | 07:24 PM
Sobe_Death's Avatar
im thinking that that drilling out a hole that small in the flywheel wont hurt it too bad being that close to the crank centerline, should really only come into play when you get rediculously high revs.
Pablomg
May 13, 2019 03:16 AM
earl
Oct 8, 2006 06:53 AM
Maddox
Mar 1, 2004 09:05 AM
boomslang
Nov 30, 2001 06:48 AM
