do all honda head have studs coming out of the exhaust ports
Old Feb 28, 2004 | 10:17 PM
EGh22aEG's Avatar
Default do all honda head have studs coming out of the exhaust ports
in every car i have ever seen when you take off the header there are studs for all the bolts. We took off the turbo manifold on my friends b18c5 hatch and there were only two and the rest were holes with screws?
Old Feb 28, 2004 | 10:23 PM
Kamin's Avatar
Default Re: do all honda head have studs coming out of the exhaust ports (EGh22aEG)
from the factory, yes they are all studs with nuts.
they have a tendency to break so replacing them with bolts is not uncommon.
Old Feb 28, 2004 | 10:25 PM
EGh22aEG's Avatar
Default Re: do all honda head have studs coming out of the exhaust ports (Kamin)
thanks
Old Feb 28, 2004 | 10:49 PM
HYBRID_H@TCH's Avatar
most all newer OBD2 heads (besides sohc) have only 2 studs (both lower corners) and have bolts for the rest.
Old Feb 28, 2004 | 10:53 PM
Kamin's Avatar
Default Re: do all honda head have studs coming out of the exhaust ports (99Hybrid_Hatch)
hmm...
i stand corrected.
Old Feb 29, 2004 | 05:16 AM
Runnerdown's Avatar
Yes indeed, the two outer most holes have studs and the rest are bolts. Studs are better clamping so go with those. Its cheaper for Honda to put bolts in there so they save 2 cents per car.
Old Feb 29, 2004 | 01:00 PM
Adam F's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99Hybrid_Hatch &raquo;</TD></TR><TR><TD CLASS="quote">most all newer OBD2 heads (besides sohc) have only 2 studs (both lower corners) and have bolts for the rest.</TD></TR></TABLE>
Old Feb 29, 2004 | 07:43 PM
boostn420's Avatar
Default Re: (Runnerdown)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Runnerdown &raquo;</TD></TR><TR><TD CLASS="quote">Studs are better clamping so go with those. Its cheaper for Honda to put bolts in there so they save 2 cents per car.</TD></TR></TABLE>
Not only that but when threads go bad its better when they're on a replaceable stud instead of the head.
Old Feb 29, 2004 | 11:00 PM
T.J.'s Avatar
Default Re: (boostn420)
yes theres 2 studs on each side of the head. It actually helps when putting a header on , it gives you something for the header to hold on to whille your screwing in the other bolts
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostn420 &raquo;</TD></TR><TR><TD CLASS="quote">
Not only that but when threads go bad its better when they're on a replaceable stud instead of the head.</TD></TR></TABLE>
This is true and it the bolt is crossthred some when you pull it out make sure you replace it , and not use it again.
90Integra_Rs
Jan 12, 2007 08:39 PM
miahmouse
Aug 17, 2006 07:27 AM
D.Dappa
Mar 11, 2005 07:53 PM
shamoo
Jan 21, 2002 02:05 PM
