***important*** sAFC + Rc 310 injector question
Old Feb 28, 2004 | 08:27 PM
showtymers619's Avatar
* B A N N E D *
Default ***important*** sAFC + Rc 310 injector question
one if on the fuel setting on a safc is set on -50% on a 440 injector = 220 which is almost stock flow
now the real question...
im planning to use 310 injectors instead.. what is the most -x amount can i subtract to get closest to stock?i figured -25% is still not close enought to stock injector flow
can some1 give me an almost exact number to get as close to stock as possible thanks in advance.. also can you also tell me how you guys figured out the actual number.. post an example thanks again
Old Feb 29, 2004 | 09:23 AM
* B A N N E D *
Default Re: ***important*** sAFC + Rc 310 injector question (ShowTymers619)
top
Old Feb 29, 2004 | 12:18 PM
Civic_95_Si's Avatar
310 x .78 = 241. So about 22% subtracted should be close to the stock 240cc.
Thats the math I came up with.
Old Feb 29, 2004 | 01:26 PM
* B A N N E D *
Default Re: ***important*** sAFC + Rc 310 injector question (Civic_95_Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civic_95_Si &raquo;</TD></TR><TR><TD CLASS="quote">310 x .78 = 241. So about 22% subtracted should be close to the stock 240cc.
Thats the math I came up with. </TD></TR></TABLE>
ok thanks..
integraRS-T
Jul 8, 2007 02:48 PM
dem0nk1d
Feb 4, 2007 11:25 AM
b20vtech
Feb 15, 2006 03:56 PM
whoneedzvtec
Jan 1, 2006 10:45 AM
