92 Accord transaxle bushing...
Old Feb 28, 2004 | 10:54 AM
improvdub's Avatar
Default 92 Accord transaxle bushing...
I want to replace the bushing that holds the passenger side transaxle in to the transmission.....how do I remove this bushing???
any help appreciated. Thanks
Old Feb 28, 2004 | 04:40 PM
improvdub's Avatar
Default Re: 92 Accord transaxle bushing... (improvdub)
anyone???
Old Feb 28, 2004 | 05:31 PM
Chiovnidca's Avatar
The axle seal?
Old Feb 28, 2004 | 07:49 PM
improvdub's Avatar
Default Re: 92 Accord transaxle bushing... (Chiovnidca)
no, not the seal...the bushing inside the transmission
Old Feb 28, 2004 | 09:32 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by improvdub &raquo;</TD></TR><TR><TD CLASS="quote">no, not the seal...the bushing inside the transmission</TD></TR></TABLE>
What bushing?
Old Feb 29, 2004 | 09:47 AM
bill-71SS's Avatar
sounds like he is talking about a diff. brg. if so,trans has to come apart
Old Feb 29, 2004 | 03:00 PM
improvdub's Avatar
Default Re: 92 Accord transaxle bushing... (bill-71SS)
no one knows what Im talking about??
Old Feb 29, 2004 | 03:05 PM
improvdub's Avatar
and can we not use abbreviations...sorry...i don't understand.
Old Feb 29, 2004 | 03:15 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by improvdub &raquo;</TD></TR><TR><TD CLASS="quote">no one knows what Im talking about??</TD></TR></TABLE>
I'm trying to find out. Describe what it is, where it is and what it does.
Old Mar 1, 2004 | 04:03 AM
improvdub's Avatar
it is a bushing...it is inside the transmission, it holds the axle from moving around while it is turning...mine seems to be broken because the axle makes a sound when I do certain things...trust me, i've replaced all other parts, so this has to be it.... THANKS
Old Mar 1, 2004 | 04:13 AM
v4lu3s's Avatar
RTFM
if it is inside the transmission i hope you are up to rebuilding the tranny. the axles slide into the tranny and into the differential, which is made up of shimes, a taper bearing, and the differential case....
Old Mar 1, 2004 | 01:34 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by improvdub &raquo;</TD></TR><TR><TD CLASS="quote">it is a bushing...it is inside the transmission, it holds the axle from moving around while it is turning...</TD></TR></TABLE>
The differential carrier?
Old Mar 2, 2004 | 06:27 PM
improvdub's Avatar
it's a brass piece that the drive shaft fits into....its got spiral grooves and theres a rubber ring right before it...
Old Mar 3, 2004 | 05:34 AM
v4lu3s's Avatar
RTFM
thre are 2 oil seals one in each half of the diff housing then inside that is this:
Endo-land
Sep 8, 2007 10:43 AM
dleccord
Jul 9, 2007 03:05 AM
nomoreavril
17
Dec 14, 2006 09:25 PM
siguy4
May 13, 2006 05:23 PM
e_r_i_c_
Mar 7, 2004 07:39 AM
