few questions about d15b7
Old Feb 27, 2004 | 11:51 PM
95dxhatch's Avatar
Default few questions about d15b7
i've done some searching and looking around to find this stuff but havent really gotten any answers.
i'm building my d15b7 motor because i cant afford a B, H or K motor. i just got a delta 272 cam for it (thanks Tad ) and i'm trying to find some valve springs and retainers for it and i cant really find anything. all i can find is stuff for d16z6 and y7s and what not. i was just wondering if all/most D series head parts like springs/retainers could be used on any head? i found this on ebay http://cgi.ebay.com/ebaymotors...33624 will those work on the b7 head (yes i know it says for z6 and y7s)? thanks in advance for any answers or tips in the right direction for this stuff.
Modified by 95dxhatch at 3:46 PM 2/29/2004
Old Feb 28, 2004 | 10:23 AM
95dxhatch's Avatar
i already have a 2nd b7 head to work on and the 272 cam. decent z6 heads at the time i bought the b7 were just too much for them. and i didnt feel like getting another ecu and wiring vtec, i'm lazy and broke. so anyone have an answer?
Old Feb 28, 2004 | 10:49 AM
mike93eh
Guest
Posts: n/a
i think they mean y8 in that ebay auction, not y7..
Old Feb 28, 2004 | 11:00 AM
95dxhatch's Avatar
auction says z6, y7, y8, y5... anyone got an answer? shouldnt be that hard. i know someones had to have built up their d15b7.
Old Feb 28, 2004 | 11:14 PM
95dxhatch's Avatar
bump... a tech question is finally being asked and no one can answer?
Old Feb 29, 2004 | 10:05 AM
95dxhatch's Avatar
last bump, then i give up here
Old Feb 29, 2004 | 10:16 AM
lohatch's Avatar
Default Re: (95dxhatch)
since the y7 is a non-vtec head i wonder if those springs would work in a B7. i personally dont have any experience with interchanging sohc valve springs i hope somebody can answer your question though so you can rev the **** outta that little sohc
Old Feb 29, 2004 | 10:20 AM
91civicDXdude's Avatar
d16y7 and d16z6 heads are the same.. casting wise and valves and everything. Y7/Z6/Y8 valves are bigger than A6/B7/B1/B2 castings, so im sure there is a height difference as well.
Old Feb 29, 2004 | 10:34 AM
hatchback19's Avatar
Default Re: (91civicDXdude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civicDXdude &raquo;</TD></TR><TR><TD CLASS="quote">Y7/Z6/Y8 valves are bigger than A6/B7/B1/B2 castings, so im sure there is a height difference as well.</TD></TR></TABLE>
Are you sure about that? I'm almost sure that it's the other way around, both the combustion chamber and valves are bigger. I belive the B7/A6 are 1mm bigger valves. I'll look more into this.
Old Feb 29, 2004 | 12:46 PM
95dxhatch's Avatar
wow some replies! thanks guys. all i really knew is the a6/b7 heads were basically the same besides the a6 having a little different cam or something along those lines. ttt
Old Feb 29, 2004 | 03:16 PM
S14sx2nr's Avatar
so theres no definitive answer to his question... and since i dont know... BUMP!
-Dan
Old Feb 29, 2004 | 07:30 PM
95dxhatch's Avatar
any word hatchback19 ? bump
Old Feb 29, 2004 | 08:34 PM
95dxhatch's Avatar
night bump
Old Mar 1, 2004 | 08:56 AM
95dxhatch's Avatar
morning bump
Old Mar 1, 2004 | 09:23 AM
mafioso102's Avatar
New User
https://honda-tech.com/zerothread?id=81824
This is the only person that I could find that has had a seemingly aftermarket valvetrain put in a d15b7. I would contact SFP or the folks at exospeed to determine what alternatives you have. Also, mistabone on here might be able to help you. I know there are large amounts of aftermarket suport for the d16a6, and since the 4gen crx/ civic si cam is intergchangeable in the dx, there is a chance that so are the other valvetrain components. While this isn't a defiitive answer, i hope it offers you some other places to look. Good luck and make sure that you post when you find out and share the knowledge
96electronH
10
Oct 6, 2007 10:55 AM
honda305
Nov 14, 2006 11:47 PM
crzyfool24
Apr 3, 2004 11:38 AM
