CEL with VAFC install and raised VTEC crossover...
Old Oct 14, 2001 | 05:39 PM
VTECHGSR's Avatar
New User
Default CEL with VAFC install and raised VTEC crossover...
Got a CEL 22(VTEC Solenoid) after raising the VTEC crossover from 4400 to 4900 in my OBD II eqipped GSR. Anyone else experience this? It seems to be intermitent too. Damn.
Old Oct 14, 2001 | 05:44 PM
sgT's Avatar
sgT
Default Re: CEL with VAFC install and raised VTEC crossover... (GSRtoR)
Did you connect the VTM wire?
Old Oct 14, 2001 | 07:42 PM
Hukd Up's Avatar
Default Re: CEL with VAFC install and raised VTEC crossover... (sgT)
what rpm does vtec kick in stock on a gsr?
jason
Old Oct 14, 2001 | 07:52 PM
nfn15037's Avatar
Default Re: CEL with VAFC install and raised VTEC crossover... (out_a_bounz)
4400=VTEC
5900(?)=secondairy intake runners
Old Oct 14, 2001 | 08:07 PM
sgT's Avatar
sgT
Default Re: CEL with VAFC install and raised VTEC crossover... (nfn15037)
5750 for IAB
Old Oct 15, 2001 | 09:31 AM
VTECHGSR's Avatar
New User
Steven, no I did not connect the VTM wire. I'm assuming this may fix my problem. I didn't know the ECU was VTM equipped. Damn. Just after I put all of those wires back into the black harness.....
Thanks for the input
Old Oct 15, 2001 | 09:39 AM
B18CXr's Avatar
hookup the VTM and problem will be solved.
Old Oct 15, 2001 | 10:43 AM
sgT's Avatar
sgT
VTM = vtec oil pressure switch.
ALL usdm cars have it.
Old Oct 15, 2001 | 10:47 AM
blktyper2001's Avatar
New User
Take out the VAFC
Old Oct 15, 2001 | 11:50 AM
TypeR0207's Avatar
Default Re: CEL with VAFC install and raised VTEC crossover... (blktyper2001)
Middle pin, blue wire with white stripe.
Cut it, tape off the engine side, connect the ECU side to the VTM wire from the V-AFC, reset your ECU, and your good to go.
Old Oct 15, 2001 | 12:10 PM
VTECHGSR's Avatar
New User
Default Re: CEL with VAFC install and raised VTEC crossover... (TypeR0207)
Thanks for the help guys
Old Oct 16, 2001 | 09:16 AM
Black R's Avatar
25 Year Member
Actually, you will want to connect both sides of this wire to your vafc... one is what vafc will recognize as vti or (vtec input from ecu) and the other is vto (vtec output from vafc). It will work as described above, but you can get info for the vti from your vafc if you connect the other wire... (diagnostic stuff, etc) and monitor with the vafc if you know what you're doing...
Old Oct 16, 2001 | 10:29 AM
TypeR0207's Avatar
Default Re: CEL with VAFC install and raised VTEC crossover... (Black R)
No .......
If you connect both to the VTM wire, you will end up with an intermittent CEL light, and I have helped people get rid of it by taking off the engine side ....
The instructions say that, not me ....
And the VTI and VTO work without doing that. The VTO actually is the signal from the V-AFC telling when to switch it over. The VTI is the signal that the computer is sending out (through the VTM wire) that the V-AFC intercepts.
If you do it the way I said (Apex-i's directions), you will be able to monitor the VTI and VTO on the V-AFC display as advertised.
[Modified by TypeR0207, 2:29 PM 10/16/2001]
Old Oct 16, 2001 | 10:35 AM
sgT's Avatar
sgT
VTI and VTM are not the same.
VTI is the vtec activation signal
VTM is the oil pressure switch signal to the ecu
Old Oct 16, 2001 | 10:42 AM
Black R's Avatar
25 Year Member
TypeR0207, I'll check later when I get a chance. You may be right about the wires...
For my itr, I used kenji's wiring harness so that may be confusing me...
Old Oct 16, 2001 | 11:18 AM
TypeR0207's Avatar
So, I'm off a little.
But not by much .....
The VTM (oil pressure switch) gets routed through the V-AFC, and is then controlled by the unit. If you have both wires connected, then sometimes you will get an errant signal that makes it through, and you will not get the VTEC crossover, and often will bog down over the x-over. Basically the same reacion as not having it hooked up at all.
Old Oct 16, 2001 | 05:23 PM
CanadaCivicSIR's Avatar
New User
vtec solenoid wire is connected to both sides of the ecu (green yellow wire)
vtm wire is blue
cut vtm wire to motor splice on ecu side
boosted1993
Mar 21, 2005 08:34 AM
1insaneR
May 10, 2004 10:19 PM
wgs0023
Feb 26, 2004 03:49 AM
egturbo
Nov 21, 2003 02:32 PM
Hybrid 350GT
Nov 11, 2002 10:24 AM
