what's the best suspension set up for the money??
what ranks up there with the tunability of konis and ground control for the money? right now I'm on my 3rd set up. 1st was S2 C/Os on white tokicos- 2nd was the same tokicos with sportlines. and now i have the progress coilover set up with custom tuning and ERS springs. The problem that i have now is that i have a blown front shock, the model coilover that i have are progress's old model and they don't offer retuning or rebuilding on those any longer. it sucks that i have to spend a G or so on suspension once again, what the best for the money? currently i have the car set up for daily driver with weekend track use 475lbs front springs with 425lbs in the rear. i need a set up that's good for AX and or RR that i can tune for different set ups. is there anything i should consider besides the koni GC set up?? and why?
any info is much appreciated.
the best suspension i have seen for the money is buddy club racing spec
they cost about 1300-1500, they have independant hieght adjustability and have 15 way rebound/dampening control
they are by far the best bang for the buck IMHO
if you want a good plave to buy them go to http://www.randdmotorsports.com
or you can give them a call at (843)760-4804 and tell them daniel sent you
do you know how high a spring rate the dampers are good upto? are they rebuildable? does buddy club offer servicing on them?
Buddy Club
shocks can handle up to 30 kg/mm
rebuildable, thru manufacturer in Japan, at no cost
I ordered a set, can't wait till they get here
Modified by Dan GSR at 3:03 PM 2/27/2004
Tru Dynamix
Jan 22, 2003 03:37 PM
The_In_Kid
Sep 14, 2002 11:46 PM
