How to reset the computer to clear OBD II code P1456
Old Feb 26, 2004 | 09:43 PM
timus's Avatar
Default How to reset the computer to clear OBD II code P1456
Hello,
I want to know if there is a way to reset yourself the computer system of Honda civic 99 model to clear the P1456 error code.
P1456 Evaporative Emissions (EVAP) Control System Leakage (Fuel Tank System)
My car failed the smog functional test due to this code which started showing up when I forgot to put the fuel cap. But now its there, still the car computer doesn't detect it.
Any advice is welcome.
Thanks
Sumit
Old Feb 26, 2004 | 10:17 PM
h2392si's Avatar
Default Re: How to reset the computer to clear OBD II code P1456 (timus)
just unplug the negative battery cable for like 15 minutes and then put it back on, thats how you reset the computer. next time try a search as i myself asked this question, peace, and good luck.
Old Feb 26, 2004 | 10:31 PM
timmy8151's Avatar
Default Re: How to reset the computer to clear OBD II code P1456 (h2392si)
Another method is to pull the 15 A & 7.5 A fuses at the top left of the fuse box.
Old Feb 26, 2004 | 10:58 PM
timus's Avatar
Thanks for your quick response. Can you please provide details about the location of the negative battery cable in the car.
thanks,
Sumit
Old Feb 26, 2004 | 10:59 PM
timus's Avatar
Default Re: How to reset the computer to clear OBD II code P1456 (timmy8151)
Thanks for your quick response. Can you please provide details about the location of the fuse box in the car.
thanks,
Sumit
Old Feb 27, 2004 | 09:57 AM
EE_Chris's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by timus &raquo;</TD></TR><TR><TD CLASS="quote">Can you please provide details about the location of the negative battery cable in the car. </TD></TR></TABLE>
Its the cable attached between your battery and the frame....usually about 8-10" in length.
Old Feb 27, 2004 | 02:02 PM
boostn420's Avatar
Default Re: How to reset the computer to clear OBD II code P1456 (EE_Chris)
To clear the codes just pull the second fuse at the top of the underhood fuse box. I thinks it raio back up or something like that. 30 seconds and the code should be clear unless there is actually a problem like a deformed o-ring in the gas cap.
Old Feb 27, 2004 | 03:55 PM
timus's Avatar
Default Re: How to reset the computer to clear OBD II code P1456 (boostn420)
Thanks a lot to everyone. Pulling off the fuses did it. I hope the car can now pass the smog check.
thanks,
Sumit
XSlor
Dec 11, 2017 01:46 PM
teamvirus
Honda Civic (2001 - 2005)
May 28, 2009 11:32 PM
achid
Honda Civic (2006 - 2015)
22
Nov 3, 2008 09:26 AM
94DCTeg
Acura TSX
Aug 2, 2008 04:32 PM
HRDCORD
May 5, 2005 10:21 AM
