Type S camshafts or Crower Stage 2?
Old Oct 14, 2001 | 11:19 AM
OneThirtyEight's Avatar
Default Type S camshafts or Crower Stage 2?
This is for my friend, he has i.h,e, valve springs, cam sprockets, ect. His valve trains is upgraded. He wants to know the power difference between the JDM type S shafts or the Crower Stage 2, which ones are better? (97, H22A)
Thanks
Old Oct 14, 2001 | 12:53 PM
JG Luder's Avatar
Default Re: Type S camshafts or Crower Stage 2? (97blackteg)
crower.
Old Oct 14, 2001 | 02:41 PM
HRC's Avatar
HRC
Default i'm biased
s-sticks.
Old Oct 14, 2001 | 03:24 PM
97RedLudeSH's Avatar
New User
JGLuder, i see you recomend the crower, can you tell me the advantage of these over the Type S??
I'm the guy getting the cams...
I'm most likely going with crower, but i just wanted to see if you had an additional information i may not know about.
thanks
[Modified by 97RedLudeSH, 12:28 AM 10/15/2001]
Old Oct 14, 2001 | 07:09 PM
John's Avatar
New User
Default Re: Type S camshafts or Crower Stage 2? (97RedLudeSH)
if i remember correctly, Crower H22 cams were "replicas" of the Type-S cams...
Old Oct 14, 2001 | 08:32 PM
Mike95lude's Avatar
Crower is much better. Type-S will cost the same if not more than Crower and won't make as much power. So therefore Type-S cams aren't that great a "value" imo. Also theres the talk of compatibility problems with USDM H22A's rocker arms and the S cams...the cams create abnormal wear supposedly.
Old Oct 15, 2001 | 03:56 AM
LudeBehavior's Avatar
New User
Default Re: Type S camshafts or Crower Stage 2? (Mike95lude)
I was thinking bout the same thing. the type s cams you cn notice the pull higher up on the rpms. The crower stage two you can feel if all through out. Normally when ya switch em to type s cams ya gotta up the valve train cause they lift kinda high. I dunno about the crower tryn to relicate the type s ones tho??
Old Oct 15, 2001 | 05:10 AM
New User
I've looked around and found that even with the stage 2 crower it recommends the titanium upgrade (which i have) and a vtec controller (which i also have).
I've ordered the crower's, thanks for the info.........i seem to remember hearing about the type-s incompatability with our h22a's as well.
thanks again
Old Oct 15, 2001 | 06:13 AM
New User
could anyone give me an idea of the power i should see from these cams? I have my mod's listed down below, without specific knowledge of these items, should i see at least the advertised 15-18hp? or should i see more?
If there is anyone out there that has the Crower Stage 2 (street/strip) camshafts please share what you think of them.
If there is big / noticible difference in power?
thanks
Old Oct 15, 2001 | 09:39 AM
JG Luder's Avatar
Sorry about your IM. I thought you were the guy that started the post....
If no one here has the Stage 2, then I'd check out http://www.hondaprelude.com and ask.
Oh, and for the open record, check the sig for my cams.
Old Oct 16, 2001 | 06:23 AM
Daemione's Avatar
Depends on how you tune them. I'm sure you could get 15-18 hp (or more) up top if you're willing to sacrifice a lot of low-end.
But as you probably know, peak numbers aren't the best picture of how fast a car is. Maintaining the area under the curve is important, as well as putting the power where you're going to need it.
BTW, at the point where you are in mods, you'll be stretching the limits of your stock fuel maps. I bet you could see a decent amount of power by going with some good fuel management (aka Hondata). A stage 2 & some dyno tuning wouldn't be all that expensive, and probably worth it. And since you'll be dynoing for the cams anyway, a basic hondata setup will only be like $260.
Of course, you'll have to deal with an OBDI conversion, and losing ATTS. So maybe it's not worth it.
Old Oct 23, 2001 | 03:29 PM
ELUD THS's Avatar
New User
Default Re: Type S camshafts or Crower Stage 2? (WadZii)
the type "s" camshaft just cause there JDM are laser etched differenly then the american crower stage 2. the type "s" of course which you already have done , you need to upgrade your internal such as valve springs and retainers. my friend actually have a type "s" cam shaft in his 5th generation prelude and the only real difference that you could feel on a dyno is the mid to high end power. as for 15-18 hp? well i think he only averaged bout 10-12 give or take , but you do feel a little better pull on the stage 2 crower cause they way it was etched turned your camshaft lobes to work more agressive in vtec and mid range ~
Old Oct 23, 2001 | 08:48 PM
ImportReview
Guest
Posts: n/a
Default If anyone....
Is from SOUTHERN CALIFORNIA...
If you have some H22A cams...
I am looking for some cam testing material...
I will install your cams, give you a valve adjustment, and dyno tune your car, with BEFORE and AFTER results for $150.
Total.
I need H22A testers! Bring in your S cams! YOur Crower cams!! Your JUN CAMS!
WE TEST PRELUDES.
jeff
Old Oct 23, 2001 | 10:34 PM
Backyard Speical's Avatar
hey i'm kind of new to this board. well i got some info on the crowers and the type S cams that i thought maybe i could share it with you guys.
one of my friend has the crower stage 3 cams on the h22a it made about 15 HP, thats with the crower valve train. and some guy long long long time ago he had the type S cams, and it only mad about 8 HP. so for the money i would 100% go with the crower cams.
BUT...... why not wait for the JUN3s? the JUN3s made so much HP on the B series motors, and for prelude motors it should make way more than the B series.
http://www.prodigyworks.com
[Modified by Prodigy 2.2 EK, 7:35 AM 10/24/2001]
Old Oct 24, 2001 | 01:00 AM
Meateater's Avatar
New User
Default Re: Type S camshafts or Crower Stage 2? (Prodigy 2.2 EK)
maybe because it costs 2000 dollars without the ecu...JUN
Old Oct 24, 2001 | 09:58 AM
Default Re: Type S camshafts or Crower Stage 2? (Meateater)
well when those cams come out why don't you guys give me a call or email me, maybe i can give you guys a better deal on those JUN3 setup
vtec4deaththo
14
Jun 2, 2009 08:11 AM
Kendawg386
Sep 6, 2007 08:06 AM
B18_Hatch
Jan 8, 2005 08:30 AM
Prelude004
Jan 15, 2002 10:47 AM
