clutch set-up?
You should buy a new clutch kit (disk, PP, throwout bearing, and piolt bearing) Once something breaks you want to make sure you change everything, as everything wears together.
With most any brand you should be able to buy just a disk... I also wouldn't recommend just buying a disk if you planning on running your current clutch till it goes (that's also wearing on the pressure plate, etc.)... It is possible to damage your pressure plate but like I said it depends on how long you're planning on going... When it comes time to change your clutch, pull the pressure plate and inspect it... While everything is off (unless you've changed recently) I would swap the throwout/pilot bearings, and resurface the flywheel... As ultimatehonda said, you really should just buy a new kit... Just my $0.02
i put a centerforce in about a 8 months ago, but i thought about getting a 6 puck disk for it and using my centerforce pressure plate. i am going to get a lightened flywheel when i go my clutch and a new t.o.b. too so
or
as far as doing a new disk?
or
blue_hatch
Sep 1, 2008 06:30 PM
miguel6632
Nov 29, 2006 08:37 AM
