HELP ME OUT! plug gasket leak
Old Feb 26, 2004 | 11:53 AM
PLACEBO's Avatar
Default HELP ME OUT! plug gasket leak
Wassup,
This happened before, but it apparently has happened again.
The gasket around the spark plug has died again, this time two of them.
This means that there is oil in and around my plugs.
This means no spark.
Anyone off the top of their heads know a solution to get my car up and running?
MY GF IS WAITING AT THE TRAIN STATION!
This is while i am at work btw.
BOO!
Old Feb 26, 2004 | 12:34 PM
samaccord's Avatar
Default Re: HELP ME OUT! plug gasket leak (PLACEBO)
if ya want an ultra temporary quick fix, take a screwdriver and push a paper towel down the hole, make sure not to put too much of the paper towel down, or it will get stuck, but enough that it'll start to soak up some oil. I usually take the paper towel and scrunch it into a long strip, and push one end in with the screwdriver. Leave the paper towel in there for a little bit, until it starts soakin up some oil, and repeat as necessary.
Old Feb 26, 2004 | 12:36 PM
PLACEBO's Avatar
I tried that, but i didn't leave it in.
Thanks for the help!
You will be rewarded with 213 virgins in the afterlife.
Old Feb 26, 2004 | 02:14 PM
samaccord's Avatar
Default Re: (PLACEBO)
woohoo!
Old Feb 27, 2004 | 11:03 AM
PLACEBO's Avatar
Thanks for the help! after several, several times, the beast finally fired up.
32 dollars for a whole new gasket set.
THANKS!
Old Feb 27, 2004 | 11:32 AM
SteelSeal's Avatar
Here's real help!
There is a product -- Steel Seal -- developed years ago by a guy at dupont. I used it for blown head gasket on 95 Pontiac Sunfire and it worked. Cost is $44.95 -- it takes about two hours to know if it works and its guaranteed! This stuff rocks so much that I asked the company to make me a rep. They shipped me a couple of cases of the stuff and I've been taking it around to shops -- Email me and I'll get you set up!
Old Feb 27, 2004 | 11:48 AM
v4lu3s's Avatar
RTFM
umm the rubber gasket around the spark plug tubes sure doesnt need a seal like a head gasket does....sounds like a good way to attach the valve cover to teh head gasket to me.
Old Feb 27, 2004 | 11:59 AM
SteelSeal's Avatar
Default Re: (v4lu3s)
Depends on why the engine is over heating -- this product won't hurt the rubber or plastic -- it simply doesn't adhere.
Old Feb 27, 2004 | 01:16 PM
PLACEBO's Avatar
This product is interesting...i'll let you know if i still have trouble with my h22 dropped in.
Thanks for the help yo!
Old Mar 1, 2004 | 09:22 AM
aznbrwnchld's Avatar
another way to suck them out is tampons! :D
Old Mar 1, 2004 | 09:26 AM
fw190bvi's Avatar
Default Re: (aznbrwnchld)
u need a new gasket..simple as that
Old Mar 1, 2004 | 09:39 AM
RUBZERK's Avatar
Default Re: (fw190bvi)
Dont over tighten the valve cover. rings will last longer
Old Mar 1, 2004 | 09:43 AM
fw190bvi's Avatar
Default Re: (RUBZERK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RUBZERK &raquo;</TD></TR><TR><TD CLASS="quote">Dont over tighten the valve cover. rings will last longer</TD></TR></TABLE>
or u could snap off the bolt and then ud be screwed unless u got a dremel
cooxen77
Jun 26, 2019 05:54 PM
sl0whatch
Jun 1, 2010 06:15 PM
2ndchirp
Mar 31, 2008 03:43 PM
luciffer
Mar 18, 2005 07:43 AM
fasteddy91
Apr 4, 2003 08:43 AM
