5000rpm cut off problem
Well since the last oil change on my car (maybe a month or so) i've seen the performance droped A LOT;
the oil changed as been done by my father since I had no time to do this, he used 5w30 mineral penzoil.
so here's my problem:
When I hit hard on the pedal the engine won't go over 5000rpm, it seems like the engine is lacking of something. When i'm in first gear, their's almost no problem, sometime it do cutoff but someother time not. in second gear it happens more often and in 3rd, it's always a cut-off at 5000rpm. so i supposed the problem is related with engine load, maybe vtec engagement problem.
i've checked the ignition, looked good, but cleaned it up just in case, nothing changed, i've tried to clean the intake filter, but since I didn't had anything to clean it with, I just took the vacuum cleaner, maybe the filter is still blocked... the problem really began after the oil changed, that's for sure, maybe the oil is too thick and vtec is hardly engaging, before this time i've only put syntetic oil, but lack of $$.
my car is a 4cyl 2002 accord coupe, and over here we have winter with a lot of snow and cold temp. but it's beggining to get hotter, but no changes.
need help please, don't want to go at the dealer since I don't want to lose my car for a week for a small problem
What if you slowly press on the pedal, can you go over 5000 rpms?
at first glance i am thinking
blocked air filter... Try removing it for now and see
bad gas.... Sometime you can get bad gas at the pump. Has this symptom happened with a fresh tank of gas?
Catalytic converter is blocked up
just a thought here...
fs
fs
I can go over 5000rpm in first gear if i don't press to hard on the gas
i'll check on my way to my job if I remove the air filter, it's less then 2-3km
bad gas, don't think since it's for a month at different gas station
catalytic converter, it's a 2 years old car, so don't know how it can be blocked??
don't know what you want to know?
yes I have a cut-off alway on 3rd at 5000rpm, where it should be at 6750. don't know if it's from the fuel or the ignition
Now, just re-read your post. You say
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JSMC »</TD></TR><TR><TD CLASS="quote">Well since the last oil change on my car (maybe a month or so) i've seen the performance droped A LOT;
the oil changed as been done by my father since I had no time to do this, he used 5w30 mineral penzoil.</TD></TR></TABLE>
If it was fine before the oil change, and right after it started to do this, it could be related to something that was disconnected or hit by chance...
Retrace the steps your father took... Look around the engine, underneath the car... look for something he could of hit...
fs
fs
that's what i've thought, but never think it would be a good idea to check back
btw we can scratch the air filter, i've tried without it and still cut-off at 5000rpm
Hey got the same problem here, 5000rpm it almost falls on its face, not under a load though. replaced cap,rotor,coil,plugs gapped .028,wires,timming, i just have no idea
Bogging @ higher RPM can be a few different things. Fuel or Air supply issues, ignition problems and/or restrictive exhaust. Seems as though you have most of the ignition system replaced, how about the fuel filter & air filter? Ever done a fuel injection/fuel system cleaning? EGR system cleaning. Also change the PCV valve.
Hey guys, i'm new here. (posted this on another thread - this seems to be close and active)
I don't think its much off topic so here goes.
I have a d16y5 engine on an ek sedan which bogs at 5000 rpm. I've changed the fuel pump, filters (air, fuel and oil) new oil, plugs and distributor and yes no CEL codes.
all stock save for SRAM (recently cleaned element) intake and apexi muffler.
Out of frustration, tried to disconnect the vtec solenoid socket and tried it out. Surprisingly, it did reach the red line. (CEL was on)
I reconnected the solenoid, reset the ECU and again no codes.
I'm stumped.
BTW, i also changed: Engine temp sensor (the one below the distributor) and IACV recently. tried the MAP sensor of a friend as well.
In terms of drivability and power (before 5000rpm) its great. its just really irritating for the engine stop revving at 5000 rpm.
Please help!
oh and one more thing. this is my original motor. no swaps at all.
I'm stumped.
Please help!
check your ground wires clean or change them always check the easy simple things firs there always the problem one of my friends own a 1999 honda civic cx hatchback with the d16y7 and his does that to it has no power and just hits 5000 rpm and blahhhhh popping etc every gear wont spin tires no matter how hard he tries i had a y7 before and it had loads of power compared to this and another friend of mine owns a 1994 honda accord lx and his does the same he has the f22 and its got n power aswell i feel like i can get out and walk faster but i have a big feeling its a lack of power to the ecu or the ecu is fried check wiring fuzes etc hope this helps im going to be working on there car soon if i find out the ill keep you guys updated
Honda told me it was due to having aftermarket plugs and wires. So I replaced plugs,wires, cap, and rotor. No fix vtec does work but at 5000 rpm or so it so t shirt unless I let off of the pedal, then get back on it. I know it is not in the transmission, as I have replaced it due to other issues and the problem still exists.
Verify your factory tach is reading correctly. Pretty common for the tach to start reading progressively lower. Mine 'cuts out' at 5Krpm, but on an ancillary tach it reads correctly/cuts out at the right rpm.
I'm stumped.
Please help!
I'm stumped.
Please help!
Hi,
havr you solve your problem? i have the same issue in my civic.
Thanks
jon4444
Jun 27, 2015 11:48 PM
Dan Page
Engine Management and Tuning
Oct 20, 2011 02:12 AM
