does a 55 shot of nitrous pull as hard as 5 psi of boost
Old Feb 25, 2004 | 09:35 PM
typesguy's Avatar
Default does a 55 shot of nitrous pull as hard as 5 psi of boost
well i finially rode in a turbo car the other day it was an 99 civic si he was running 5psi. Now i am getting ready to go 55 shot of juice on my 99 gsr would the 55 shot pull as hard as 5 psi of boost, cuz i've never ridin in a car with nitrous. i just want to kinda get a feeling of what it's like.
Old Feb 25, 2004 | 11:29 PM
pissedoffsol's Avatar
25 Year Member
Default Re: does a 55 shot of nitrous pull as hard as 5 psi of boost (jaydmdc2)
5 psi is relative. you can't compare a pressure level to a power level
Old Feb 26, 2004 | 04:11 AM
typesguy's Avatar
ttt
Old Feb 26, 2004 | 05:36 AM
m R g S r's Avatar
Default Re: (jaydmdc2)
From my experience, I was running a dry 70 shot with a NOS system. Then I took that off and got a t3/t4 running 6.5 psi, and it pulled alot harder than the N20.
Old Feb 26, 2004 | 05:42 AM
M.A.R.C.'s Avatar
Default Re: (m R g S r)
it really depends. i ran 55 shot on my motor before boost. and because it was 55 shot on a stock motor... only intake it didn't pull like 5psi on my turbo. also i've beaten a 7th gen civic with a 50 shot vs me @ 5-6psi. but it's hard to compare especially since nitrous cars benefit a lot from the usual BPU's
Old Feb 26, 2004 | 05:43 AM
mitch83's Avatar
Just FYI a good equation is for every 1psi of boost you can 10whp and its a 9x out of time 10 result.
mitch
Old Feb 26, 2004 | 06:01 AM
HybridKOOP's Avatar
Default Re: (mitch83)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mitch83 &raquo;</TD></TR><TR><TD CLASS="quote">Just FYI a good equation is for every 1psi of boost you can 10whp and its a 9x out of time 10 result.
mitch</TD></TR></TABLE>Wrong.
Do you see the guys setups on here with say... an SC61? Making 350+ at like 10 psi? Using your math, a 140whp low compression GSR motor plus 10psi would make 240whp.
It all depends on the size of the turbo, the size of the motor, etc.
Old Feb 26, 2004 | 06:03 AM
M.A.R.C.'s Avatar
Default Re: (HybridKOOP)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HybridKOOP &raquo;</TD></TR><TR><TD CLASS="quote">Wrong.
It all depends on the size of the turbo, the size of the motor, etc.</TD></TR></TABLE>
yah but it's just a way of estimating... hell my car made about 11-12whp per psi on my setup. stock d16y8 makes ~105whp i made 172whp @ 6psi. it's a good way to guesstimate though
Old Feb 26, 2004 | 06:25 AM
Finest's Avatar
Default Re: (CivicRyda2k)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicRyda2k &raquo;</TD></TR><TR><TD CLASS="quote">
yah but it's just a way of estimating... hell my car made about 11-12whp per psi on my setup. stock d16y8 makes ~105whp i made 172whp @ 6psi. it's a good way to guesstimate though</TD></TR></TABLE>
There's a slight difference between a D16 vs. B18c when it comes to output.
Old Feb 26, 2004 | 06:27 AM
M.A.R.C.'s Avatar
Default Re: (98CTRCoupe)
well that is obvious... but like i said... it's a good way to guesstimate
Old Feb 26, 2004 | 06:28 AM
baphomet's Avatar
lmao
Old Feb 26, 2004 | 07:20 AM
BoostedSi's Avatar
Default Re: (devnull)
i think the 55shot in a gsr would pull similar to an si with 5psi. Riding in the si it would probably feel like it pulls harder tho.
Old Feb 26, 2004 | 07:36 AM
mildly.interesting's Avatar
I've sprayed 125 on a D16, and now putting 13 lbs in a B18c, there is no comparison...the n2o has a more linear feel to it, like a traight smooth pull, where as the boost is more sudden, like KABOOM here we go!
Old Feb 26, 2004 | 08:42 AM
25 Year Member
Default Re: (mildly interesting)
worst thread ever
Old Feb 26, 2004 | 08:51 AM
twkdCD595's Avatar
Default Re: (pissedoffsol)
apples and oranges.
Old Feb 26, 2004 | 01:25 PM
sydag5's Avatar
Default Re: (twkdCD595)
who cares which one pulls harder. Nitrous will run out eventually.
Old Feb 26, 2004 | 01:58 PM
b18b1hmtlove's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pissedoffsol &raquo;</TD></TR><TR><TD CLASS="quote">worst thread ever </TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pissedoffsol &raquo;</TD></TR><TR><TD CLASS="quote">worst thread ever </TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pissedoffsol &raquo;</TD></TR><TR><TD CLASS="quote">worst thread ever </TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pissedoffsol &raquo;</TD></TR><TR><TD CLASS="quote">worst thread ever </TD></TR></TABLE>
1 Cam Wonder
Nov 26, 2004 11:30 AM
hybrid901
Jul 15, 2002 02:29 PM
degradated
Jan 3, 2002 11:16 PM
Cru_Jones
Jul 21, 2001 04:31 PM
