lengthening sensor wires for mpfi swap
Old Feb 25, 2004 | 08:18 PM
type Gendy's Avatar
Default swap distributor plug for mpfi swap??
I tried searching but didnt find anything specific..
For you guys that went to dual point to B series, did you have to extend any wires, for the tps , iac or anything??
I 've heard of some people needing to, while others no (in general)
I thought since B series are bigger and sit back farther, it may not be needed?
Modified by sick hatchem at 7:25 PM 2/28/2004
Old Feb 25, 2004 | 09:59 PM
Redline130's Avatar
Default Re: lengthening sensor wires for mpfi swap (sick hatchem)
Nothing on my car had to be extended.
Old Feb 26, 2004 | 03:53 AM
type Gendy's Avatar
Default Re: lengthening sensor wires for mpfi swap (Redline130)
Cool, thanks.
How long did it take you to do it? (First time)
Old Feb 26, 2004 | 04:01 AM
Fobtions's Avatar
ive done mpfi conversions in about 2 hours. this is soldered and reloomed also.
Old Feb 26, 2004 | 04:09 AM
type Gendy's Avatar
Default Re: lengthening sensor wires for mpfi swap (Fobtions)
Sounds like you got it down pat
Old Feb 26, 2004 | 04:12 AM
RobbieG35's Avatar
12 Years Strong
I had to extend my TPS, and the plug the plugs into the third runner on the intake manifold (cant think of the name). Besides that everything else was fine.
Old Feb 26, 2004 | 04:19 AM
type Gendy's Avatar
Default Re: lengthening sensor wires for mpfi swap (HybridHatch88)
With what motor?
Old Feb 26, 2004 | 05:56 AM
Fobtions's Avatar
just use fourthgenhatch.com s write up. its easy
Old Feb 27, 2004 | 02:53 PM
type Gendy's Avatar
What would i do if i installed a b16 into a dx, for the distributor plugs?
Would i clip off the dx plugs and solder on new plugs that fit the b16?
Old Feb 27, 2004 | 03:08 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sick hatchem &raquo;</TD></TR><TR><TD CLASS="quote">What would i do if i installed a b16 into a dx, for the distributor plugs?
Would i clip off the dx plugs and solder on new plugs that fit the b16?</TD></TR></TABLE>
What I did was got the Si style plug and re-pinned it on to the DX harness..
adding the two extra wires for the crank sensor..
No cutting was necessary..
Old Feb 27, 2004 | 03:10 PM
Blaze45's Avatar
Brrraaaap!
You gotta get a male connector to hook to the B16 female plug on the dizzy, you have to run like two or four wires from the ECU to the dizzy. I also had to lengthin added to all those listed above n some dizzy wires and my IAT sensor wires.
Blaze
Old Feb 27, 2004 | 03:17 PM
type Gendy's Avatar
Default Re: lengthening sensor wires for mpfi swap (Blaze45)
So that would be the same as pinning all the wires into a b16 connector...thats a lot of pins to remove
Old Feb 28, 2004 | 03:26 PM
type Gendy's Avatar
can i just cut the plug off the dx harness and sodder on the b16 plug?? Then run the two crank sensor wires in?
Old Feb 29, 2004 | 09:50 AM
88DXCRX's Avatar
Sure,If you want to do it the hard way...
89ED
20
Dec 28, 2018 01:23 PM
Race Eend
Sep 11, 2015 02:02 PM
xprometheusx
Jun 9, 2014 08:06 AM
JerseyTrueBlue
Feb 8, 2010 08:14 PM
ZCVTEC-SOHC
19
Jul 24, 2003 11:15 AM
