What managment to run my car on for the time being?
Old Feb 25, 2004 | 05:56 PM
NyQuiL's Avatar
Default What managment to run my car on for the time being?
I currently have an aem ems with a set or 720cc siemen dekka injectors, but my local tunner is tied up untill mid to late march. So untill then im going to pick up a set of dsm 450cc injectors and try to run something in the mean time. Here are my considerations:
vafc hack with 3bar
or
fmu
or
try to use the basemap on the aem ems for 450cc injectors (i have limited knowlegde on the aem ems, so im reluctant on this one)
Anyone recomend one over the other or recomend something else entirely? I heard the hack screws your timing, so couldnt this be redone with a msd btm? and i heard the fmu is pretty bad because it could signifigantly raise fuel pressure to a dangerous level, but couldnt this also be undone with a fpr? im sorry if some of my facts or off base. Any help will be appreciated, thank you.
Old Feb 25, 2004 | 07:32 PM
2000GSRT's Avatar
Default Re: What managment to run my car on for the time being? (NyQuiL)
I think the easiest thing to do would be to keep your stock injectors and run an FMU. Just keep the boost LOW and make sure you retard your timing until you can get it tuned.
Old Feb 25, 2004 | 07:38 PM
NyQuiL's Avatar
Default Re: What managment to run my car on for the time being? (2000GSRT)
thats an option to, dosent sound to fun, but an option nonetheless.
thank you.
Bump for more ideas.
Old Feb 25, 2004 | 07:46 PM
T-RO's Avatar
Sell the EMS and just run one of the FREE ROM Editors that are floating around.
Old Feb 25, 2004 | 07:53 PM
2000GSRT's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NyQuiL &raquo;</TD></TR><TR><TD CLASS="quote">thats an option to, dosent sound to fun, but an option nonetheless.
thank you.
Bump for more ideas. </TD></TR></TABLE>
You can run low boost for a month can't you? Is it worth it to risk your motor?
Old Feb 25, 2004 | 07:54 PM
NyQuiL's Avatar
Default Re: (T-RO)
i might do this down the line, but for know id feel much safer knowing somone compitent tunned my car,
Old Feb 25, 2004 | 08:04 PM
2000GSRT's Avatar
Default Re: (NyQuiL)
I thought you were looking for a temporary solution until you could get the car to a tuner.
Old Feb 25, 2004 | 08:13 PM
NyQuiL's Avatar
Default Re: (2000GSRT)
well if i go off your method, the stock injectors are 240cc i believe, and me wastegate has a 7pound spring. would a fmu and stock inectors hold that?
Old Feb 25, 2004 | 08:59 PM
2000GSRT's Avatar
well you're looking at some pretty high fuel pressures +120psi, so you would probably need an inline fuel pump, people do it, but it's not something you want to run permanently.
Or if you don't like that idea, just take the spring out of your wastegate, might get kinda loud though, but it won't cost you anything.
Old Feb 26, 2004 | 09:01 AM
NyQuiL's Avatar
well i have all the fuel mods i will require
walbro 255, fpr, ge fuel rail...
Old Feb 26, 2004 | 10:03 AM
revhigh96's Avatar
do the afc hack. it works soo good and you dont even need the 3 bar when you are under 10psi. its really easy to hook up and drives great.
I went from an FMU to the hack it was night and day
Then I went from the hack to the AEM and again it was just that much better
overall the hack is easy and a lot better then an FMU
if you really want to go FMU I got one for sale, but I wouldnt recomend going that route
Edit: just to let you know, I put 2k miles on my car with the hack running 7psi with 9.6:1 CR, never had any problems and my EGT stayed well under the safe limit
Old Feb 26, 2004 | 11:08 AM
Joseph Davis's Avatar
Default Re: (revhigh96)
Blah.
Old Feb 26, 2004 | 12:48 PM
NyQuiL's Avatar
Default Re: (J. Davis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J. Davis &raquo;</TD></TR><TR><TD CLASS="quote">Blah.</TD></TR></TABLE>
integra95
Sep 25, 2003 04:37 PM
ARACER25
Aug 4, 2003 06:21 PM
twkdCD595
Jul 10, 2003 05:52 PM
civictypenos
Oct 19, 2002 05:28 PM
Drag III Integra
Jan 26, 2002 10:13 AM
