Subs on stock HU?
Old Feb 25, 2004 | 04:26 PM
brickonwheels's Avatar
Default Subs on stock HU?
I just bought a car today, a 96 integra ls, and it comes with the factory cd player. I already have subs that i am going to be putting in so my question is, how would i hook up the subs to the stock HU? Or do i need to get an aftermarket one?
Old Feb 25, 2004 | 04:58 PM
vtec_yosh's Avatar
Default Re: Subs on stock HU? (brickonwheels)
All you need to buy is a line out converter from a local stereo shop.
Old Feb 25, 2004 | 05:21 PM
What does that do?
Old Feb 25, 2004 | 05:42 PM
GAtegs's Avatar
Unless your amp has high level inputs, then you can use those.
Old Feb 25, 2004 | 07:56 PM
swatdog's Avatar
Your amp needs to have some feature called "speaker level input" or "high level input." If so, go to your local audio store and buy a convertor. You're gonna need to splice some wires to make everything work.
I use a stock HU with my bass setup and it works fine, but it could be better.
Old Feb 25, 2004 | 08:50 PM
snoochtodanooch's Avatar
Default Re: (swatdog)
line level.... now i know why i love rca's
Old Feb 26, 2004 | 04:04 AM
So for the best sound it would be better to get an aftermarket HU?
Old Feb 26, 2004 | 05:31 AM
Default Re: (brickonwheels)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brickonwheels &raquo;</TD></TR><TR><TD CLASS="quote">So for the best sound it would be better to get an aftermarket HU?</TD></TR></TABLE> yes it would, and they are not that much money. But if you want it stockgo with the line level inputs.
Old Feb 26, 2004 | 12:43 PM
And a line level input would be fine for my rockford fosgate 501s amp?
Old Feb 27, 2004 | 01:18 PM
not sure, look at the advice above and they were telling you what to look for. should be a series of pins for an adapter that came with the amp.
Old Feb 27, 2004 | 01:32 PM
GAtegs's Avatar
I'm not 100% sure, but I don't think this amp has them.
Do yourself a favor, d00d, buy a nice aftermarket deck and be done with it.
Old Feb 27, 2004 | 03:00 PM
Damn it, i guess i am in the market for a new HU then
Old Feb 3, 2008 | 03:58 AM
TightEyez's Avatar
will any cheap aftermarket HU work? Im looking at HU's less than $80
sorry to revive this thread but I didn't want to make a new one
Old Feb 3, 2008 | 11:32 AM
.Thomas's Avatar
Default Re: (TightEyez)
No, you need RCA outputs ....
usually the 80$ just look/preform a little better then stock.
Old Feb 4, 2008 | 10:52 PM
DISROK1's Avatar
in car audio, you get what you paid!
Old Feb 5, 2008 | 01:49 PM
Frickr's Avatar
Default Re: Subs on stock HU? (DISROK1)
those converters are junk... sorry to say but for use with subs they are junk... i had one hooked up to an l7 solobaric and 600w amp, and the bass was there, but it wasnt exact, and sounded sloppy and distorted. ended up blowing the sub in about a month of playing it.
Old Feb 9, 2008 | 07:12 PM
Electrodynamic's Avatar
Most LOC's are junk. There are some out there (Navone LOC's the RF 3Sixty.1's and .2's, the new AudioControl units, etc) are great. The RF and Audiocontrol units are much more than just an LOC, as they have EQ, time alignment, and crossover slope and frequency adjustment. The Navone unit is the best "standard" LOC I've ever used. I used it in a BMW 325i and had fantastic results.
Old Feb 10, 2008 | 02:15 PM
fcm's Avatar
fcm
Old Fart
For sub bass just about any "LOC" will work, the better the "LOC" is, the better the SQ will be.
A processing unit, like a JL Audio Clean Sweep... http://mobile.jlaudio.com/prod...id=94 IMO one of the best out there, is going to cost you as much as a pretty good HU, and unless there is a real compelling reason to keep the stock HU, replace it with an aftermarket HU, but be prepared to spend around $150 - $200 for a HU from an authorized dealer to get something that is a step up from the stock HU
Otherwise $20 will get you one that will do the job just fine... http://www.scosche.com/product...D/994
Hint, install the LOC by the HU and run RCAs and a control lead to the amp, that way if you decide to get an aftermarket HU all you need to do is swap out the HUs. 94
exhil
Aug 15, 2008 06:45 AM
elitetuning
Audio / Security / Video
Dec 13, 2005 09:52 AM
Gant
Sep 4, 2005 11:45 AM
davejj40
Mar 9, 2005 07:34 PM
danteisme
Mar 1, 2005 06:15 AM
