For those running Spoon N1 with stock b-pipe...
I just recently installed the Spoon N1 axle-back with my stock B-pipe and whenever I'm driving normally and shift above 3k rpm, I hear rattling in between shifting into gear. I don't think the problem is inside the N1. Now, I replaced the exhaust bolts that connected the axle-back with the b-pipe due to severe rusting seen on the old bolts. Could these new bolts be the culprit? I'm still in search of a nice b-pipe, it's just this rattling in the mean time is annoying the hell out of me. Did any of you guys suffer the same problem with just the Spoon axle-back?
Thanks
Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thk »</TD></TR><TR><TD CLASS="quote">I didn't have any rattling problems whatsoever when I had a Spoon N1 and OEM B-pipe.</TD></TR></TABLE>
Thats because you were never driving that fast
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yellow blur »</TD></TR><TR><TD CLASS="quote">Are you using the correct combination of hangers? </TD></TR></TABLE>
what he said. try adjusting them and it will probably get rid of the rattle. also, try to go under the car and see where it may be making contact.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec.dc2 »</TD></TR><TR><TD CLASS="quote">bolts are probably not tight enough</TD></TR></TABLE>
Thanks for the help guys. When I purchased the new bolts, I had to use the old springs and find matching nuts at a local home depot...is that probably it? I'll probably try using a lock washer also.
