Bad Wheel Bearing check?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tweakmeister »</TD></TR><TR><TD CLASS="quote">I grab at the 6 and 12
this is correct. 9 and 3 would check for outer or inner tie rod looseness.
</TD></TR></TABLE>this is correct. 9 and 3 would check for outer or inner tie rod looseness.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dan GSR »</TD></TR><TR><TD CLASS="quote">also, you should take off the axle nut to get a better indication if the bearing is no good</TD></TR></TABLE>
i disagree. u can have a wheel bearing feel loose with the axle nut off, then tighten it up and the "play" in the bearing will go away.
yes, that is a false sense of tightness
a good wheel bearing will have no slop even when the axle nut is off
if u have to depend on the axle nut to hold the bearing together, its gonna take a **** soon
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dan GSR »</TD></TR><TR><TD CLASS="quote">yes, that is a false sense of tightness
if u have to depend on the axle nut to hold the bearing together, its gonna take a **** soon</TD></TR></TABLE>
good point, its been 3 1/2 yrs since i was a front end tech. i just replaced my wheel bearings on the front of my civic over the off season. kinda forgot about the point u just made.
bgslash98
Apr 22, 2008 07:21 AM
4door93civic
13
Feb 18, 2008 07:19 PM
