ef b18a timeslips (did search)
Old Feb 25, 2004 | 12:50 AM
civicracer13's Avatar
Default ef b18a timeslips (did search)
i did a search and found nothin
i have a spare b18a im thinkin about building with pr3 pistons and a 2 layer head gasket should be 11.08:1 compression. im also gonna port and polish the head. does anyone know how much hp this will make or 1/4 mile time with ls tranny in a ef thanx
Old Feb 25, 2004 | 02:35 AM
nick.na's Avatar
Default Re: ef b18a timeslips (civicracer13)
I am not positive as I have not run a setup like that...so I have no slips. I would assume you could dip pretty far into 14's with the mods you list. A VERY WISE investment would be a b16/gsr trans!! You will be MUCH happier! I have never run an LS with internals other than cams personally, but I have had quite a few LS swaps and never broken through the 15 mark on an LS tranny
Old Feb 25, 2004 | 04:51 AM
slow hatch's Avatar
Default Re: ef b18a timeslips (075nick)
yeah, with that set up probably be high, mid 14s. A b16 tranny would help alot.
Old Feb 25, 2004 | 03:18 PM
whiteknightef's Avatar
invest in a b16 head aswell, you will lower your timeslips faster than getting a different tranny. frankenstien all the way baby
Old Feb 25, 2004 | 03:33 PM
neutron91's Avatar
Default Re: (trigger69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trigger69 &raquo;</TD></TR><TR><TD CLASS="quote">invest in a b16 head aswell, you will lower your timeslips faster than getting a different tranny. frankenstien all the way baby</TD></TR></TABLE>
Old Feb 25, 2004 | 03:37 PM
Malgerus's Avatar
Default Re: (neutron91)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by neutron91 &raquo;</TD></TR><TR><TD CLASS="quote">
Why? I'd say it's true (If done right, properly built. Still, I'd agree on the B16 tranny as well.
Old Feb 25, 2004 | 03:38 PM
91civicDXdude's Avatar
i ran a 15.5 in my 91 hatch, b18a1, i/h/e. 2.4 60' on shitty tires... an LS hatch with bolt ons could pull low 15s, so high compression pistons and some headwork should net you about mid 14s on some good *** tires or drag radials
Old Feb 25, 2004 | 07:13 PM
Default Re: (91civicDXdude)
thanx alot for the help
Old Feb 25, 2004 | 07:26 PM
JCRacer18's Avatar
I ran a 13.62@101.7 with a B18A1, clutchmasters stage 3 clutch, Intake, and 30 shot NOS. This was on 20x8x14 slicks
Old Feb 26, 2004 | 09:05 AM
EF_LSVtec's Avatar
Default Re: (JCRacer18)
stock B18b, Y1 tranny (B16), jdm 4-1 header, CAI, HKS exhaust, ACT clutch...14.6 (Azenis tires)
Old Feb 26, 2004 | 02:49 PM
neutron91's Avatar
Default Re: (Mr. S)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. S &raquo;</TD></TR><TR><TD CLASS="quote">Why? I'd say it's true (If done right, properly built. Still, I'd agree on the B16 tranny as well.</TD></TR></TABLE>
not an ls/crvtec fan... b16 tranny is cool though
Old Feb 26, 2004 | 04:13 PM
G2turbo_terror's Avatar
Keep in mind that cable b16 trannys are not exactly laying around.
Old Feb 26, 2004 | 04:47 PM
neutron91's Avatar
Default Re: (G2turbo_terror)
hydro conversion kit... hasport saved us again
Old Feb 26, 2004 | 05:11 PM
LsPoweredEF's Avatar
i got a 90 crx dx with a b18a a couple bolt ons and ran 14.8@93mhp i now it could do better but ive been able to get consistant times , with a zex 50 shot and timming retarded to 15degrees with a bad launch and spinning tire in 2nd and 3rd i ran a 14.3@98mph could do way better ,,,,,,,,had a friend that had a b18a in a ef with 3 angle valve job , itr pistions and drag radlis he ran a 14.1@99.mph so i geuss ull net around 150 to the wheels
Boosted_90Teg
Transmission & Drivetrain
15
Mar 6, 2013 11:05 AM
hybridmiklo
47
May 25, 2011 04:18 AM
Mr si99
Jun 24, 2005 09:09 AM
EFM_ookie
Jun 2, 2005 06:10 PM
