Turbo for my d16y7
Old Feb 24, 2004 | 04:31 PM
JDMproject17's Avatar
Default Turbo for my d16y7
its too big ? for a 6psi setup
A number of compressor and turbine options are available all featuring excellent map width,pressure ratio and efficiency.
Enhanced durability compressors are available.
Standard Features
* Choice of turbine housing materials to cover a wide range of temperatures.
* Compressor and turbine wheels selected for optimum airflow, efficiency and pressure ratio.
* Fully adjustable compressor and turbine housing orientation.
* Fully floating twin hydrodynamic journal bearings.
* High efficiency compressors with broad operating ranges.
* High pressure ratio capability.
* Superback compressor wheels for extended life and durability at high turbo speeds.
* Symmetrical twin flow turbine housings.
* Variety of compressor and turbine housing flanges available.
Optional Features
* CNG Engine version.
* MWE (Map Width Enhancement) compressor inlet.
* Sound suppression baffles.
* Watercooled bearing housings.
Dimensions HX35
Length mm 224
Width mm 250
Height mm 169
Smallest Mass kg 9
Largest Mass kg 11
Airflow kg/s 0.46
Old Feb 24, 2004 | 04:42 PM
TurboJesse
Guest
Posts: n/a
Default Re: Turbo for my d16y7 (JDMproject17)
nice should see full boost @ redline...maybe
Old Feb 24, 2004 | 04:48 PM
i will buy for 150$ canadian !
its a deal ?
Old Feb 24, 2004 | 05:01 PM
Tad's Avatar
Tad
yeah.. imo thats waayyyyyy too big for 6psi
especially on a d16y7.
get a t25, it'll be perfect
Old Feb 24, 2004 | 05:05 PM
HybridKOOP's Avatar
Default Re: (Tad)
T4 turbine on that bitch? Keep it far away from a SOHC...
Old Feb 24, 2004 | 05:17 PM
tegmech's Avatar
Default Re: (HybridKOOP)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HybridKOOP &raquo;</TD></TR><TR><TD CLASS="quote">T4 turbine on that bitch? Keep it far away from a SOHC...</TD></TR></TABLE>
Old Feb 24, 2004 | 10:05 PM
shadow103rd's Avatar
you need to have the RPM capability of a bike........14k redline might show 3 lbs....keep it away from a sohc
Old Feb 24, 2004 | 10:28 PM
ATS*Mark's Avatar
OG triple OG
Default Re: Turbo for my d16y7 (shadow103rd)
throw that sucker on there , it will LOOK cool
hawkturbo
Jan 30, 2009 10:37 AM
jdmb16acivic
Aug 12, 2006 12:04 PM
hondaspeder
Jul 13, 2003 10:37 AM
Project_SOHC_EX
May 11, 2003 01:17 AM
