Filtering bass from speakers???
Old Feb 24, 2004 | 11:23 AM
Crono139's Avatar
Default Filtering bass from speakers???
My friend just got the chance to listen to my sound system today. He said it sounded pretty nice, but it would sound a lot better if I were to get rid of the bass for the speakers, and my only bass would be what my two 12" subs are making.
I think I can change that with my HU. But I'm not sure what that feature would be called.
Can any of you guys shine some light on this topic? Thanks.
Old Feb 24, 2004 | 11:33 AM
GAtegs's Avatar
Default Re: Filtering bass from speakers??? (Crono139)
Get crossovers.
Old Feb 24, 2004 | 12:32 PM
rcurley55's Avatar
New User
what headunit?
Old Feb 24, 2004 | 12:34 PM
Crono139's Avatar
Default Re: (rcurley55)
Pioneer DEH-760MP.
Old Feb 24, 2004 | 01:44 PM
rcurley55's Avatar
New User
Default Re: (Crono139)
if it has a built in crossover, the set the highpass filter on the front and back speakers and the low pass filter on the sub output...
Old Feb 24, 2004 | 02:06 PM
Crono139's Avatar
Yeah, it definitely has that feature.
HPF had choices of Off, 50, 80, and 120.
Old Feb 25, 2004 | 12:37 AM
Coolson's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crono139 &raquo;</TD></TR><TR><TD CLASS="quote">Yeah, it definitely has that feature.
HPF had choices of Off, 50, 80, and 120.</TD></TR></TABLE>
80 would be good
Old Feb 25, 2004 | 10:55 AM
Crono139's Avatar
Default Re: (Coolson)
I just set it to the highest. Sounds a lot clearer.
Old Feb 28, 2004 | 10:22 AM
SyDuck's Avatar
u like it highest?? sometimes wen i bump soungs... the subwoofers play the highs and it owns my ears. i have my x-over at 150.. everytime i bump "atmoshere-saves the day" the subs do the highs and i end up changing the song bcuz the sub's highs drive me nutz
Old Feb 28, 2004 | 12:40 PM
EBP_SI's Avatar
Default Re: (SyDuck)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SyDuck &raquo;</TD></TR><TR><TD CLASS="quote">i have my x-over at 150</TD></TR></TABLE>
thats pretty high. i dont think id do any higher than 80hz
Old Feb 28, 2004 | 01:51 PM
GSteg's Avatar
i have my midrange HP at ~250hz
Old Feb 28, 2004 | 02:17 PM
EBP_SI's Avatar
Default Re: (GSteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSteg &raquo;</TD></TR><TR><TD CLASS="quote">i have my midrange HP at ~250hz</TD></TR></TABLE>
do you have dedicated midbass drivers?
Old Feb 28, 2004 | 04:52 PM
GSteg's Avatar
yes sir!
I'm using my el cheapo stock speaker for midbass and the Vifa PLs for midrange. My image dynamic cd2comp horns should be coming soon.
Old Feb 28, 2004 | 07:55 PM
rjr162's Avatar
Default Re: (GSteg)
Your other option is to get some "bass blockers" (IE&gt; Passive cross-overs, also known as capacitors). Stereo shops sell them for like $15 a pair... IIRC the values you want are either 99 uF for 200 hz and below blocked to 4 ohm speakers, or 199 uF which do 400 and below (I might have those switched). You can pick them up at radio shack for around 99 cents a peice.
Old Feb 29, 2004 | 09:10 PM
dmbmalaka's Avatar
The pioneer heads usually have great crossovers, but if you want like complete lack of bass form the speakers you can buy these resister type things that you just put inline with the speaker wires. Those work best but they are usually like 5$ a piece at best buy . good luck
deerman2701
Audio / Security / Video
11
Apr 16, 2008 12:28 PM
redDAinteg
May 6, 2006 09:38 AM
ITB
Dec 4, 2005 07:26 AM
Bubble Gum Jr.
Apr 28, 2003 11:52 AM
Mike D
May 6, 2002 01:34 PM
