People with sleeved blocks.
Specifically those running 2.0 blocks. I was curious to see if you have any overheating issues.
I would think that the cylinder walls on a bored out/sleeved block would be a lot thinner and as a result cause the engine to run hotter. Just a thought. Am i way off here?
I'm thinking of going 2.0L but am not sure if i want B20 or sleeved B18c. Lots o pros and cons on both.
There will be dimished cooling by using a B18 block. I don't see any pros to resleeving a B18. Go for the B20 unless someone has any reason not to.
once u resleeve blocks... as in this case to bore over to 84mm... the only issues could run into is the durability... the b20 block has stronger sleeves in stock forum but once a b18c block is sleeved it becomes the stronger of the two... to add to it... if u have ever looked at an "ls" block and compare it to a vtec block... u would notice a big differance... side by side just the form of the blocks are differant... in the way they are reinforced... and then it has oil squirters as well if u want them
does anyone know if its possible to press out the complete cylinder bore from a b18a and press b20 sleeves/bore(whatever you call the whole assembly) into it? That would make essentially a b20 block correct?
If u ask me nothing beats a VTEC block! The oil squirters included on the VTEC motors help with the cooling of the piston due to the increased piston speed of the VTEC motor. If anything I think the B20 block is the weaker of the 2.
The B20 actually has stronger sleeves than any other B block and has stronger bearings too. I think for reliability and simplicity, just get a B20.
7rrivera7
11
Jul 29, 2006 09:51 PM
GQ 05YellowEVO8
Feb 18, 2003 09:04 PM
