MSD quick question (internal coil honda CRX)
Old Feb 24, 2004 | 07:07 AM
djnikko's Avatar
Default MSD quick question (internal coil honda CRX)
hi guys
im wiring a msd ignition box (6AL) to my honda CRX my question is how do most people get the wires from inside the cap (once its screwed back on) to the MSD box? do i just drill a hole and poke the wires through. also I take it the rotor arm will still be spinning so should i tape them out the way of this? any help would be greatly appreciated
Old Feb 24, 2004 | 07:30 AM
CRXRageD's Avatar
Default Re: MSD quick question (djnikko)
thats what I did, the leads are coming out of the cap. I did try to seal the hole with some rubber cement. don't want moisture getting into the cap. could corrode you connectors.
Old Feb 24, 2004 | 07:43 AM
WONG FRIED RICE's Avatar
u basically got it...if u want it to look clean try to make the hole on the bottom of the cap so u can't really see it.
Old Feb 24, 2004 | 02:07 PM
somethinwikd's Avatar
Default Re: MSD quick question (JDMB16ACRX)
the other thing you can do is pull the wires back out of the little rubber gromet that is already in the distributor... pull the rubber out trim it a little to fit the 2 wires and put it back on... saves drilling a hole not that it would hurt anything unless water got in there???
Old Feb 25, 2004 | 02:11 AM
djnikko's Avatar
Default Re: MSD quick question (somethinwikd)
ok I drilled a hole to accomodate, seems to be ok but now Ive managed to wreck the heads of the two screws for the + and - of the coil. Any one got any suggestions on how I can get them out? Ive put WD40 maintenance spray on them and left them over night....
Old Feb 25, 2004 | 04:50 PM
needle nose vice grips tightened down as far as you can get them... squeez real hard... only way i got mine off when i did my sci...
Old Feb 26, 2004 | 01:10 AM
Xsi's Avatar
Xsi
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by somethinwikd &raquo;</TD></TR><TR><TD CLASS="quote">the other thing you can do is pull the wires back out of the little rubber gromet that is already in the distributor... pull the rubber out trim it a little to fit the 2 wires and put it back on... saves drilling a hole not that it would hurt anything unless water got in there???</TD></TR></TABLE>
This is what I did
Can you not just cut the wires off the coil and pull it out?
Old Feb 26, 2004 | 06:59 AM
kappa12's Avatar
Default Re: MSD quick question (Xsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djnikko &raquo;</TD></TR><TR><TD CLASS="quote">Ive managed to wreck the heads of the two screws for the + and - of the coil. Any one got any suggestions on how I can get them out? </TD></TR></TABLE>
I took a dremel and cut a big *** slot in the top of both of them. I was then able to use a larger flathead screwdriver to get them out with no problem whatsoever.
JOeiROck
Mar 31, 2006 10:26 PM
USDM 4G VTEC
Feb 15, 2004 10:45 AM
_Endless_
Jan 22, 2003 12:58 AM
Acura_I-RS
Jun 6, 2002 03:57 PM
