Help Help problem
ok , i got my car aligned ,balanced and i slap 2 new tires in the front ,still no cigar .
when im climbing from 30mph to 40 mph my car slightly shakes , but when i let go the gas it stops the shaking .also when im going from 65mph to 70 mph it shakes also .is like mostly when you punch it around that speed it vibrates,i got an aligment ,balance 4 tires ,2 new tires in the front ,and still i cant get rid of that .could that be the bushings ???? let me know if someone can help me .thanks
I had this problem no more than 2 months ago. My car should shake as soon as
it hit 40 MPH or so. No noticable problems anywhere including a bent rim. Then
one night I'm sitting at a red light getting ready to turn right. I tap the gas to go
and my right front axle snapped. Then I knew what the vibrating was. I haven't
had a problem since then.
well thanks for the help . im going to change the axel and bushings also , to see if i still have the problem . is weird cause i only get the shake when i punch it .
ej8love1
Suspension & Brakes
May 2, 2009 09:54 PM
