Help Help problem
Old Feb 24, 2004 | 05:49 AM
MasterSaif's Avatar
Default Help Help problem
ok , i got my car aligned ,balanced and i slap 2 new tires in the front ,still no cigar .
when im climbing from 30mph to 40 mph my car slightly shakes , but when i let go the gas it stops the shaking .also when im going from 65mph to 70 mph it shakes also .is like mostly when you punch it around that speed it vibrates,i got an aligment ,balance 4 tires ,2 new tires in the front ,and still i cant get rid of that .could that be the bushings ???? let me know if someone can help me .thanks
Old Feb 24, 2004 | 05:53 AM
foursquarepunk04's Avatar
have you tried putting the tires from the back to the front to see if its a bent rim ?
Old Feb 24, 2004 | 05:56 AM
MasterSaif's Avatar
Default Re: (foursquarepunk04)
no i didnt do that , for the simple reason that running a smaller 15 in the front so they dont rub .
Old Feb 24, 2004 | 06:21 AM
TurboedGSR's Avatar
Default Re: (MasterSaif)
when was the last time you had your tie rods replaced?
a shop would let you know if your wheel is bent when balancing.
Old Feb 24, 2004 | 06:47 AM
93-GSR's Avatar
Default Re: (TurboedGSR)
sounds like one of your axles may be going out........
Old Feb 24, 2004 | 07:09 AM
stasi's Avatar
Default Re: Help Help problem (MasterSaif)
I had this problem no more than 2 months ago. My car should shake as soon as
it hit 40 MPH or so. No noticable problems anywhere including a bent rim. Then
one night I'm sitting at a red light getting ready to turn right. I tap the gas to go
and my right front axle snapped. Then I knew what the vibrating was. I haven't
had a problem since then.
stasi's Avatar
Default Re: Help Help problem (stasi)
should = would. typos suck. =/
Old Feb 24, 2004 | 07:10 AM
JBBNJ609's Avatar
sounds like you need to learn how to make thread titles better
Old Feb 24, 2004 | 08:44 AM
MasterSaif's Avatar
well thanks for the help . im going to change the axel and bushings also , to see if i still have the problem . is weird cause i only get the shake when i punch it .
ej8love1
Suspension & Brakes
May 2, 2009 09:54 PM
boost fed ls
Nov 14, 2004 07:09 PM
Project X
Jul 11, 2003 10:36 AM
b18c1-t
Jan 9, 2003 06:04 PM
