Bushing Install Write-up
Old Feb 23, 2004 | 07:50 PM
Mugenlude's Avatar
Default Bushing Install Write-up
Looking for a write-up for a complete bushing install. Does anyone have a link?
Thanks,....
Old Feb 24, 2004 | 06:02 AM
Mugenlude's Avatar
Default Re: Bushing Install Write-up (Mugenlude)
^^^^ anyone, even if it's not for a EF... anything might be helpful.
Old Feb 24, 2004 | 07:50 AM
HondaPartsHero's Avatar
Technical Hero
http://honda.hybrids.jp/tech/howtos/bushings.shtml
this is the only one i can find, i am going to be doing mine in the next month so i will try to do one and post it, but sometimes i get lazy to take pictures
Old Feb 24, 2004 | 07:54 AM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
A few links for suspension bushing replacement:
Link#1
Link#2
Link#3
Link#4
Link#5
Modified by 88DXCRX at 3:54 PM 2/26/2004
Old Feb 24, 2004 | 07:55 AM
AgentJam's Avatar
I'm in the middle of the ES master kit installation...
I found this... http://www.crxsi.com/resources...4.htm
Honestly just get a shop manual for your car so you know how to get the control arms and all off and then choose your weapon...20 ton press or torch and hack saw (one is easier which do you think?). I searched for write ups but once i started i realized that there isn't much to it...just a lot of work and getting really mad.
Good luck!
Vince
Old Feb 24, 2004 | 08:19 AM
90civichbsi's Avatar
Default Re: Bushing Install Write-up (88DXCRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88DXCRX &raquo;</TD></TR><TR><TD CLASS="quote">A few links for suspension bushing replacement:
Link#1
i looked at this site when doing mine
Old Feb 24, 2004 | 10:15 AM
Mugenlude's Avatar
Great, thanks for the links guys... these will help out A LOT!
Old Feb 24, 2004 | 06:05 PM
JCracer723's Avatar
Default Re: (Mugenlude)
has any1 tried this???
adding some fittings to the arms for a grease pump
Old Feb 24, 2004 | 06:18 PM
killercrx's Avatar
New User
Send me your stuff we can do it at my shop , for a small fee.i have done many of cars not a problemi'll help you out.
Old Feb 25, 2004 | 05:34 AM
AgentJam's Avatar
Default Re: Bushing Install Write-up (killercrx)
I'm going to do the zerk fitting install...napa near my house has 8 fittings for $6. I'm just going to try to tap every singe bushings i can.
Vince
Modified by AgentJam at 4:01 PM 2/25/2004
Old Feb 25, 2004 | 08:52 AM
xci_ed6's Avatar
Default Re: Bushing Install Write-up (AgentJam)
i was also going to add zerk fittings, everything on he farm has them except my car (even the dodge ram).
-Dustin
Old Feb 25, 2004 | 09:05 AM
JCracer723's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AgentJam &raquo;</TD></TR><TR><TD CLASS="quote">I'm going to do the zerk fitting install...napa near my house has 8 fittings for $6. I'm just going to try to tap every singe bushings i can.
Vince
Modified by AgentJam at 4:01 PM 2/25/2004</TD></TR></TABLE>
how hard and safe is this?? and wut kinda grease pump would i have to get ?
Old Feb 25, 2004 | 09:24 AM
Technical Hero
Default Re: Bushing Install Write-up (JCracer723)
this is one you could use, get it at a parts store for 20 bucks or less
Old Feb 25, 2004 | 09:44 AM
kid-honda's Avatar
Bushings are a long job but I swear its the best mod for $$$ you will see.
This whole job is pretty straight forward.
I have a press so it wasnt to bad.
Old Feb 25, 2004 | 10:08 AM
AgentJam's Avatar
Default Re: Bushing Install Write-up (yebabee)
yeah i just cleaned up my control arm bushing areas today and tomorrow i'm going to tap them all...wondering what grease everyone will be using...
Lithium grease?
How about brand???
Vince
Old Feb 25, 2004 | 10:11 AM
JCracer723's Avatar
is it safe to tap the control arms ( to install the fitting)?? wut if i dont use the fitting .. but i lubricate them once in a while .. would it be the same???
just wanna make sure before i go on and decide if to tap or not
Old Feb 25, 2004 | 10:19 AM
FULL-RACE EP3's Avatar
Default Re: (JCracer723)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JCracer723 &raquo;</TD></TR><TR><TD CLASS="quote">has any1 tried this???
adding some fittings to the arms for a grease pump</TD></TR></TABLE>
Great idea
Old Feb 25, 2004 | 10:23 AM
AgentJam's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JCracer723 &raquo;</TD></TR><TR><TD CLASS="quote">is it safe to tap the control arms ( to install the fitting)?? wut if i dont use the fitting .. but i lubricate them once in a while .. would it be the same???
just wanna make sure before i go on and decide if to tap or not </TD></TR></TABLE>
Yes...well, what's unsafe about it? As long as it's just a small clean drilled hole it will be fine. And why not use the fittings? They are less than a dollar a piece? They will also keep grease from leaking out after you lube it up.
Vince
Old Feb 25, 2004 | 10:30 AM
i used mobil 1 sythetic grease on mine
Old Feb 25, 2004 | 10:37 AM
AgentJam's Avatar
Default Re: Bushing Install Write-up (90civichbsi)
how long since you lubed it? any squeaks?
Vince
Old Feb 25, 2004 | 11:07 AM
rice_classic's Avatar
This is exactly what I did.
I have zerk fitting into my LCA's and my rear trailing arm bushings. I used the ES master bushing kit and the instructions off http://www.overboost.com
Old Feb 26, 2004 | 01:13 AM
Xsi's Avatar
Xsi
I did a RTA bushing write up for my DA: http://www.integra.orcon.net.nz/rta might help
Old Mar 1, 2004 | 08:47 AM
AgentJam's Avatar
Default Re: (Xsi)
I have an extra set of 8 Zerk tap fitting from NAPA. I bought these and then left them at work this weekend. I didn't want to drive all the way here and pick them up so i just bought another set...if someone needs them let me know, you can just pay shipping i don't need them.
Vince
Old Mar 1, 2004 | 05:42 PM
brianbrannon's Avatar
Default Re: (AgentJam)
I really dont think lubeing the outside of the bushing is going to do you any good. The bolt moves inside the bushing not the bushing inside the arms
Old Mar 2, 2004 | 04:44 PM
88DXCRX's Avatar
Default Re: (brianbrannon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brianbrannon &raquo;</TD></TR><TR><TD CLASS="quote">I really dont think lubeing the outside of the bushing is going to do you any good. The bolt moves inside the bushing not the bushing inside the arms</TD></TR></TABLE>
They probably drilled a hole all the way to the center of the bushing...
