Bushing Install Write-up
Technical Hero
Re: Bushing Install Write-up (Mugenlude)
http://honda.hybrids.jp/tech/howtos/bushings.shtml
this is the only one i can find, i am going to be doing mine in the next month so i will try to do one and post it, but sometimes i get lazy to take pictures
I'm in the middle of the ES master kit installation...
I found this... http://www.crxsi.com/resources...4.htm
Honestly just get a shop manual for your car so you know how to get the control arms and all off and then choose your weapon...20 ton press or torch and hack saw (one is easier which do you think?). I searched for write ups but once i started i realized that there isn't much to it...just a lot of work and getting really mad.
Good luck!
Vince
Good luck!
Vince
Re: Bushing Install Write-up (88DXCRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88DXCRX »</TD></TR><TR><TD CLASS="quote">A few links for suspension bushing replacement:
Link#1
i looked at this site when doing mine
Link#1
New User
Send me your stuff we can do it at my shop , for a small fee.i have done many of cars not a problemi'll help you out.
Re: Bushing Install Write-up (killercrx)
I'm going to do the zerk fitting install...napa near my house has 8 fittings for $6. I'm just going to try to tap every singe bushings i can.
Vince
Modified by AgentJam at 4:01 PM 2/25/2004
Vince
Re: Bushing Install Write-up (AgentJam)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AgentJam »</TD></TR><TR><TD CLASS="quote">I'm going to do the zerk fitting install...napa near my house has 8 fittings for $6. I'm just going to try to tap every singe bushings i can.
Vince
Modified by AgentJam at 4:01 PM 2/25/2004</TD></TR></TABLE>
how hard and safe is this?? and wut kinda grease pump would i have to get ?
Vince
Re: Bushing Install Write-up (yebabee)
yeah i just cleaned up my control arm bushing areas today and tomorrow i'm going to tap them all...wondering what grease everyone will be using...
Lithium grease?
How about brand???
Vince
Lithium grease?
How about brand???
Vince
is it safe to tap the control arms ( to install the fitting)?? wut if i dont use the fitting .. but i lubricate them once in a while .. would it be the same???
just wanna make sure before i go on and decide if to tap or not
Re: (JCracer723)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JCracer723 »</TD></TR><TR><TD CLASS="quote">has any1 tried this???
adding some fittings to the arms for a grease pump</TD></TR></TABLE>
Great idea
Great idea
Re: Bushing Install Write-up (JCracer723)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JCracer723 »</TD></TR><TR><TD CLASS="quote">is it safe to tap the control arms ( to install the fitting)?? wut if i dont use the fitting .. but i lubricate them once in a while .. would it be the same???
just wanna make sure before i go on and decide if to tap or not </TD></TR></TABLE>
Yes...well, what's unsafe about it? As long as it's just a small clean drilled hole it will be fine. And why not use the fittings? They are less than a dollar a piece? They will also keep grease from leaking out after you lube it up.
Vince
Vince
Re: (JCracer723)
This is exactly what I did.
I have zerk fitting into my LCA's and my rear trailing arm bushings. I used the ES master bushing kit and the instructions off http://www.overboost.com
Re: (Xsi)
I have an extra set of 8 Zerk tap fitting from NAPA. I bought these and then left them at work this weekend. I didn't want to drive all the way here and pick them up so i just bought another set...if someone needs them let me know, you can just pay shipping i don't need them.
Vince
Vince
Location: I told you to wait in the truck in Texas, United States
Re: (brianbrannon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brianbrannon »</TD></TR><TR><TD CLASS="quote">I really dont think lubeing the outside of the bushing is going to do you any good. The bolt moves inside the bushing not the bushing inside the arms</TD></TR></TABLE>
They probably drilled a hole all the way to the center of the bushing...
