Help,My car dont rev pass 7500 rpm
Hey guys, I have a h22 turbo with a Haltech engine managment that doest go pass 7500rpm its not a fuel cut its an ignition cut. Its not my ignition box or coil is there a way that it could be my distributor thats bad is there any way i can check that .
Whitelude: Learn to read. He is running a HALTECH system. There is no stock ecu.
Jaxx4k: A built engine will handle a higher rpm than 7500 safely and not blow.
Shararti: *shakes head* Since he can easily change the rev limit on the Haltech, I am pretty sure, he would have already checked that.
anyway, back on topic.
Do you have an MSD ignition?
that could be messed up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jz »</TD></TR><TR><TD CLASS="quote">if its boosted and he has a decent sized turbo im sure hes making power up there. VERY often do boosted hondas make power way up there on the rpm band, turbo size pending. so no one can really say anything about him revving past 7500. until he says he is making power up there. which im sure he is if hes wanting to rev that high. </TD></TR></TABLE>
i would like to see some dynographs to back that up
I have A Garrett Gt35/Gt40 dual ball bearing turbo aka really big turbo. it starts to spool at 5000 rpm so i want those extra rpms but it cuts off at 7200. can the distributor be the problem
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lildrgn »</TD></TR><TR><TD CLASS="quote">
that could be messed up.</TD></TR></TABLE>
since you missed my last question.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SKDRCR »</TD></TR><TR><TD CLASS="quote">
i would like to see some dynographs to back that up</TD></TR></TABLE>
just tell me if you want some more graphs, i have plenty saved on the puter also
Jabbito
Nov 8, 2015 03:24 PM
