stock 1g dsm bov psi?
Old Feb 23, 2004 | 04:23 PM
dan89crxsi's Avatar
Default stock 1g dsm bov psi?
at what psi does the 1g dsm bov release the pressure and if im only running a internally wastegated turbo at 8psi would it be pointless to run a 1g dsm bov?
Old Feb 23, 2004 | 04:36 PM
T-RO's Avatar
a BOV doesnt release pressure at any PSI... it releases pressure when you take your foot off the gas so the incomming air doesnt smack into the closed throttle plate
Yes run one
Old Feb 23, 2004 | 04:37 PM
dan89crxsi's Avatar
Default Re: (T-RO)
ok thanks man
Old Feb 23, 2004 | 04:51 PM
danl's Avatar
Banned
Default Re: (dan89crxsi)
A 1g DSM BOV starts leaking at around 17 psi, give or take. Crush it and it can hold 25 psi and more. The BOV starts bleeding pressure when the differential pressure between the signal line and the charge pipe is around 5 psi, give or take a few psi.
Old Feb 23, 2004 | 07:45 PM
blown_LS's Avatar
Default Re: (danl)
Just crush it and i'll hold like a charm
Old Feb 23, 2004 | 08:03 PM
NyQuiL's Avatar
Default Re: (blown_LS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blown_LS &raquo;</TD></TR><TR><TD CLASS="quote">Just crush it and i'll hold like a charm </TD></TR></TABLE>
ditto, 1st gen dsm blow off valves are amazing, crushed there even better.
Old Feb 23, 2004 | 08:14 PM
Hoodwinked's Avatar
Default Re: (NyQuiL)
not to jack your thread, but when you say "crush it" what does that exactly mean?
Old Feb 23, 2004 | 09:39 PM
tilt's Avatar
Default Re: (Hoodwinked)
its when you literally crush the top part of the bov, like with a hammer.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hoodwinked &raquo;</TD></TR><TR><TD CLASS="quote">not to jack your thread, but when you say "crush it" what
does that exactly mean?</TD></TR></TABLE>
Old Feb 23, 2004 | 10:09 PM
Hoodwinked's Avatar
Default Re: (tilt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tilt &raquo;</TD></TR><TR><TD CLASS="quote">its when you literally crush the top part of the bov, like with a hammer.
and how does this allow it to hold more pressure?
Old Feb 23, 2004 | 10:19 PM
Blackack26's Avatar
I believe it compresses the spring inside
Old Feb 23, 2004 | 10:23 PM
Deluzional's Avatar
Default Re: (Blackack26)
Would it be worth the time to crush the bov even if I was running only 8psi? From old rumors that I never actually cleared up, I heard it was harmful
Old Feb 23, 2004 | 10:40 PM
lazerus's Avatar
Default Re: (Deluzional)
no reason to crush unless you're going over 15 psi, really..
it takes a matter of 15 seconds to crush one in a vice though. Crush it so the vacuum nipple touches the lower ring slightly and you 're all good to go.
wernhersey
Dec 5, 2007 09:58 AM
deeweezy187
Aug 20, 2007 08:53 PM
teefunk01
Oct 20, 2005 08:18 AM
DeadLock23
Nov 13, 2003 08:39 PM
GOLDBERG
Jul 29, 2003 01:49 PM
