Seat belt Question????????????
Old Feb 23, 2004 | 10:35 AM
jayjay's Avatar
Default Seat belt Question????????????
The recoil on my driverside seat belt sucks! Can anyone tell me if it's repairable, or do I need to get a new one???????????
A little Yellow and proud of it..................
Old Feb 23, 2004 | 11:10 AM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Default Re: Seat belt Question???????????? (jayjay)
Supposebly,The seatbelts are warrantied for the useful life of the vehicle..
If you take it to a dealer,they are supposed to fix it for free
as long as the malfunction is not a product of alteration/abuse or neglect..
If you still have the "warranties" booklet that came with the owners manual
of your car,This is clearly stated within it..
I have heard of dealers not wanting to honor this which in that case the owners contacted
American Honda Motors directly before anything was done for them..
Old Feb 23, 2004 | 11:21 AM
jayjay's Avatar
Default Re: Seat belt Question???????????? (88DXCRX)
Wow that's news to me....................
Thanks .................
Old Feb 23, 2004 | 12:29 PM
pyro_freak8's Avatar
hmm, what else is waranted?
Old Feb 23, 2004 | 12:52 PM
RCautoworks's Avatar
Default Re: (pyro_freak8)
You will need adobe acobat reader to read this
http://aarc.epnet.com/pdf/046000/045944.pdf
More info
Automotive Recalls and Technical Service Bulletins for 1990 Honda CRX Si L4-1590cc 1.6L SOHC (D16A6) MFI.
Provided by ALLDATA
Safety Recalls
TSB Number Issue Date TSB Title 95028 OCT 95 Recall - Front Seat Belt Buckle
Service Bulletins
TSB Number Issue Date TSB Title 98-018 JUL 03 Drivetrain - Revised CV Joint Boot Band/Installation
00-089 OCT 00 Supplemental Restraint System - Inspection
99-018 APR 00 Required Special Tools And Equipment,
98-019 MAR 00 Audio Unit - Warranty Exhange/Out of Warranty Repair
00-022 MAR 00 Torque Converter Oil Seal - Installation Tool
97-015 DEC 99 Service Publications - Availability & Ordering
99-030 MAY 99 Recommended Materials
19_1-04 OCT 98 Interior - KRYTOX(R) Fluid Applications
98-051 AUG 98 Special Tool Loan Program
98-026 APR 98 Audio Unit - Antitheft Code Labels
98-001 FEB 98 Engine/Transmission - Hydraulic Lift Truck usage
90-007 MAY 97 90-007 - 05/27/97
86-020 MAY 97 Brakes - Disc Refinishing Procedure
97-027 MAY 97 Tools - Denso HLD-100 Halogen Leak Detector
97-028 MAR 97 Body - Minor Paint Finish Repair
97-020 MAR 97 Tools - New Fuel Pressure Gauge and Replacement Parts
96042 SEP 96 Tools - Power Steering Pressure Gauge
89029 MAY 96 Radio - Warranty Exchange/Out Of Warranty Repair
89004 MAY 96 Required Special Tools & Equipment
96014 FEB 96 Tools - Belt Tension Gauge Calibration and Repair
96005 JAN 96 Engine - Idle Vibration or 'Click'
91030 JAN 96 Seat Belt - Slow to Retract
92012 JAN 96 Seat Belts - Warranty Replacement Policy
89029 DEC 95 Radio - Unit Diagnosis
90007 AUG 95 Service Publications and Supplies
89029 MAR 95 Radio - Unit Exchange/Repair
90014 SEP 94 A/T - Remanufacturing Exchange Program
94025 AUG 94 Steering - Wheel Oscillates or Has a Shimmy
88012 AUG 94 Tools - Exacta Code Key Cutter
88023 DEC 93 Battery - Testing Procedure
ATRATB200 DEC 93 A/T - Starts In Wrong Gear/No Reverse
ATRATB191 OCT 93 A/T - Failsafe Modes
93010 FEB 93 Brake - Rear Caliper Rattle
91019 FEB 93 Emissions - Label Replacement Information
92041 NOV 92 Engine - Vehicle Fails State I/M Emission Test
92040 NOV 92 Tools - Crankshaft Pulley Holder
87006 OCT 92 PDI - Shipping Wax Removal Update
ATRATB132 SEP 92 A/T - Intermittent Electrical Problems
ATRATB125 AUG 92 A/T - Bind-Up In 4th Gear
ATRATB116 JUN 92 A/T - Noise Going Into or Out Of Reverse
SN920505 MAY 92 A/C - Odors From Vents
91029 APR 92 Drive Axles - Clicking Noise While Turning
87014 MAR 92 Radio - Out-of-Warranty Audio Component Repair
SN920301 MAR 92 Parasitic Draw - Test Clarifications
SN920205 FEB 92 Fuel/Emission Notes
92001 JAN 92 Engine - Charging System Testing
ATRATB090 JAN 92 A/T - 4 Speed Pressure Specifications
90014R DEC 91 A/T - Transmission Remanufacturing Program
SN911206 DEC 91 Nose Mask - May Cloud Paint
ATRATB078 NOV 91 A/T - How To Use A Pressure Gauge
ATRATB069B SEP 91 A/T - 4 Speed Identification
ATRATB068 SEP 91 A/T - Computer Diagnostics
91019 JUN 91 Emissions - Underhood Label Replacement Information
88009 APR 91 Service Bulletin Index Update
90007 APR 91 Service Supplies and Publications
89030 MAR 91 Radio - C.D. Player Exchange Program
89004 FEB 91 Special Tools - Equipment, and Service Manual
86027 DEC 90 Tools - Engine Stand and Adapter Information
90037 DEC 90 Tools - Instructions For New Ball Joint Tool
89029 OCT 90 Radio - Exchange Program
ATRATB028 OCT 90 A/T - Engine Vacuum Testing
90028 SEP 90 Windows - Markings Under Certain Lighting Conditions
90022 AUG 90 Tools - Anti-Lock Brake Checker Repair
90017 AUG 90 Suspension - Squeaking Noise From the Rear Trailing Arm
SN900805 AUG 90 Cigarette Lighter - Switching Precautions
SN900806 AUG 90 Radio - Noise/Interference Service Tip
SN900706 JUL 90 Cassette Player - Clean Light Resetting
MEMO0790 JUL 90 Muffler - Revised Warranty
SN900705 JUL 90 Recycled R12 - Storage Tips
SN900603 JUN 90 R12 Refrigerant - Recovery/Recycling Update
SN900501 MAY 90 Oil Pan Drain Plug Hole - Thread Repair
90011 APR 90 PDI - Correcting Off-Center Steering Wheel
MEMO042790 APR 90 Replacement Battery - Limited Warranty
MEMO040690A APR 90 Replacement Parts - Warranty Extension
MEMO040690 APR 90 Security Systems - Warranty Extension
89032 MAR 90 Paint Codes
MEMO030990 MAR 90 Warranty - Claim Coding Errors
SN900301 MAR 90 Luggage Divider Latch - Rattles
SN900304 MAR 90 Water Pump - Coolant Weepage
ATRATB9002006 FEB 90 A/T - Choosing the Right ATF
89037 NOV 89 Battery - Testing Equipment
MEMO1089 OCT 89 Paint - Damaged Vehicle Repair Procedure
MEMO1089 OCT 89 Warranty Parts - Return By Federal Express Airbill
ATRATB8930 OCT 89 A/T - Math Part II
ATRATB8927 SEP 89 A/T - Twenty Steps To Successful Repairs
ATRATB8923 AUG 89 A/T - Math Formulas Part I
MEMO0889 AUG 89 Body and Frame - Rustproofing
89008 FEB 89 Tools - Check Mainshaft End Play
88036 DEC 88 Paint - PDI Inspection
ATRATB8754 SEP 87 A/T - Front Bushing Wear
ATRATB8748 AUG 87 A/T - Slipping or No-Shift/Metal Sealing Rings
Old Feb 23, 2004 | 12:56 PM
kid-honda's Avatar
Honda will replace bad belts for free, I have done it before.
Old Feb 23, 2004 | 01:12 PM
88DXCRX's Avatar
Here is a scan of the warranties booklet:
Click here for the original:
http://www.cartogra.com/servle...&size=
Old Feb 23, 2004 | 01:44 PM
B1TEM3's Avatar
just got mine replaced.
but they wont replace the rear seat belt (it wont recoil too)
Old Feb 23, 2004 | 02:13 PM
dan89crxsi's Avatar
Default Re: Seat belt Question???????????? (B1TEM3)
yeah as said above there is a technical service bulletin on those seat belts and it has a way to clean them so they will recoil.....i dont know about the dealership thing but seems like its true considering those are a safety device
Old Feb 23, 2004 | 04:20 PM
xbB's Avatar
xbB
Default Re: Seat belt Question???????????? (dan89crxsi)
Take it to another dealer if they don't fix it.
Old Feb 23, 2004 | 07:03 PM
jayjay's Avatar
Default Re: Seat belt Question???????????? (CRXcellent)
Thanks for the info, I just got done with repairing the recoil, the only thing that was holding it up was 15 years of grit and grime..... nothing mechanical..
Some spray degreaser and a Q-tip fixed it up real well..........
ardenj
Mar 21, 2017 09:45 AM
Sogotron6K
Mar 10, 2014 05:19 AM
Geo255
Jul 14, 2007 08:25 PM
Nizzy
Aug 24, 2004 07:41 PM
