Going from a D16 to B16 with same turbo...
Old Feb 23, 2004 | 08:23 AM
maxim's Avatar
Default Going from a D16 to B16 with same turbo...
Tried searching and could not come up with any results.
Currently, I am running a Drag Gen III kit on my d16y8(in a '00 civic). I am also building a B16 and would like to retain as many turbo parts as possible when I have the B16 in the car. I believe the exhaust manifold is the same with B series and D series(could be wrong though), my biggest concern is whether I can use the Drag dp and turbo piping made for the d16 with my b16. Fittment issues? Anybody have have experience with this situation?
Old Feb 23, 2004 | 08:25 AM
RyanEJ8's Avatar
Default Re: Going from a D16 to B16 with same turbo... (maxim)
Exhaust manifold is different. That may cause a problem with downpipe fitment too. Downpipe can likely be modified to fit, but you'll have to get a new manifold.
Old Feb 23, 2004 | 10:07 AM
maxim's Avatar
Default Re: Going from a D16 to B16 with same turbo... (RyanCivic2000)
Yeah, I have the B16 exhaust manifold, but just heard that d16 and B16 drag manifolds were the same somewhere.
Anybody tried this before?
Old Feb 23, 2004 | 10:09 AM
b16ahybrid's Avatar
they look the same but you would have to modify the d-series manifold to for the b-series, just like any other d-series manifold.
Your better off getting a new manifold and the dp will probably need to be modified too. the piping should work fine.
I did the same thing...
Old Feb 23, 2004 | 10:18 AM
WONG FRIED RICE's Avatar
yes, exhaust manifold will be different, downpipe will have to be modified as well, and your IC piping may need slight change too. You might also have to re-clock the turbo.
D17Dyl
K Series
Oct 13, 2018 03:17 AM
yellowjdmcrx
Sep 2, 2008 08:06 PM
Funanin
Apr 25, 2008 10:43 PM
garylythgoe
Sep 30, 2004 04:41 PM
b16booster
Jul 18, 2003 03:48 PM
