No black box on D16a6? Is this true ?
Old Feb 21, 2004 | 01:22 PM
sleeperx's Avatar
Default No black box on D16a6? Is this true ?
Ok, I have been doing my turbo install this weekend, and finished up installing the black box. I wasn't sure if I needed the check valves along with the black box, so I did a search and found out that I do not if i am using the black box. I also ran across a post that stated that the black box can not be used on pre '92 cars. I have an 88 crx d16a6. The install went fine as far as corrosponding wiring ect.... so I figured that all was well, but now I don't know if this is going to work or not, and if I need to remove the check valves or the black box.
Thanks in advance to any helpful input !
Old Feb 21, 2004 | 06:43 PM
sleeperx's Avatar
Default Re: No black box on D16a6? Is this true ? (sleeperx)
someone ... anyone ??
Old Feb 21, 2004 | 06:56 PM
ATS*Mark's Avatar
OG triple OG
not sure man....and i asume that your talking about the greddy blue box correct?
try it , if the little like is blinking green than your good to go
Old Feb 22, 2004 | 06:12 AM
sleeperx's Avatar
Default Re: No black box on D16a6? Is this true ? (Hella_JDM)
No, I am talking about the black box. The older Greddy Kits came with a black box unlike the newer kits that came with the blue box.
Old Feb 22, 2004 | 07:32 AM
Cee_mon's Avatar
I had the older style black box. I used it on a 95 though, but i was told that the black box was made for the ZC kit. Dont know if that helps at all.
Old Feb 22, 2004 | 05:03 PM
sleeperx's Avatar
Default Re: No black box on D16a6? Is this true ? (Cee_mon)
Hmmm .. not sure if that does or not, thanks for the info though .. Anyone else with some insight ?
Old Feb 22, 2004 | 06:37 PM
Joseph Davis's Avatar
The black box was an electronic choke for the MAP sensor, it's sort of like a missing link/check valves, only it doesn't **** up. It's meant for FMU based setups. You can run it on most any EFI Honda.
The later blue box is for OBD1-until stuff, it recalibrates things for larger injectors.
I'd like to hijack this thread with the following link: http://www.turboedit.org/.
That is all.
Old Feb 23, 2004 | 10:24 AM
sleeperx's Avatar
Default Re: No black box on D16a6? Is this true ? (J. Davis)
That is awesome .. thanks for jacking my thread !!
hotboxnaccord
Nov 29, 2009 02:38 PM
Integra_drk
Apr 15, 2008 05:17 PM
b18-c-rx
Jul 2, 2005 06:59 PM
