Flywheel....ITR or ACT Streetlite?
Old Feb 22, 2004 | 11:55 PM
Unjockable's Avatar
New User
Default Flywheel....ITR or ACT Streetlite?
i'm going turbo and i currently have a fidanza flywheel (was planning NA). now, should i trade my friend for his ITR(15lbs) or should i buy a ACT streetlite (12 lbs)?
Old Feb 23, 2004 | 03:41 AM
BROOD's Avatar
Default Re: Flywheel....ITR or ACT Streetlite? (Unjockable)
The ITR flywheel works really well and in my current set-up that is what I went with. After buying one of the ACT flywheels for my other car....I look back and hit myself for not putting an ACT in my Civic.
Nice piece for $255 shipped and it's SFI cert. IMO I'd go with the ACT especially if you plan on launching the car alot (drag track) or plan to use a puck clutch disk. Oem cast flywheels can weaken with over exposure to heat.
Modified by BROOD at 11:50 AM 2/23/2004
Old Feb 23, 2004 | 04:42 AM
JDEM1's Avatar
Default Re: Flywheel....ITR or ACT Streetlite? (BROOD)
i was stuck in the same boat, decided to stick with oem, since its barely a difference from oem si flywheel, i will be getting the act xact flywheel next time i change out the clutch , btw hows the fuel pump working
Old Feb 23, 2004 | 10:48 AM
Unjockable's Avatar
New User
Default Re: Flywheel....ITR or ACT Streetlite? (JDEM1)
the fuel pump works but i'm still having the start up problem. i'm pretty sure it's the main relay. thanks for the pump though.
Old Feb 23, 2004 | 10:49 AM
boosted_dc2's Avatar
go with the act, its the perfect weight IMO. thats what im running...
Landon
Old Feb 24, 2004 | 06:27 AM
Paluce's Avatar
Default Re: Flywheel....ITR or ACT Streetlite? (boosted_dc2)
ACT all the way. I think 12lbs is a great weight for a daily driver.
redline760
Apr 10, 2009 06:35 AM
ReddotsS2K
Honda S2000
31
Feb 26, 2008 01:20 PM
93sivtec
Apr 22, 2007 08:57 AM
BEE1
Aug 13, 2005 07:14 AM
cw98typer
Mar 17, 2003 07:53 PM
