what new clutch/flywheel for my EM1???
Well my car(99 EM1) is in need of a new clutch and/or flywheel, its my daily driver btw. The most common problem that im experiencing is slippage. One thing is for sure is that "I do not not race at all", but the only time i beat on it is when I go around corners. The two clutch sets im looking at right now are both by Exedy; the OEM replacement or the Single Plate Organic. Which would be best for me? As far as flywheels go im not so sure if i need one or not, will surfacing my stock flywheel be enough for my needs or should i go ahead and purchase a Fidanza(sp?)? thanks.
Re: what new clutch/flywheel for my EM1??? (EBPimpSi)
flywheel is your choice, but you can just have your OEM resurfaced; lighter flywheel sometimes messes with your Idle, depending on how lighter they get. Exeddy clutch should be fine. I bought the stage one; a bit stiffer in the pedals than stock; but holds great for cars that are 200hp and below. Im sure the one your looking for is a stepdown from the stage one but will have OEM feel.
95GSRBOI
11-01-2012 09:01 PM
