Fields v-afc
Old Feb 22, 2004 | 10:14 PM
turboZChatch's Avatar
Default Fields v-afc
I searched but found nothing I have a 90 hatch with a built turbo motor I am trying to wire in my v-afc but I can not read japanesse and thats all it came with can some on tell me how to wire this to a chipped pr4 ecu?
Old Feb 23, 2004 | 11:51 AM
Another B16's Avatar
New User
Default Re: Fields v-afc (turboZChatch)
If it is a fields try this address. http://prelude.vtec.net/gen5/p....html.....
I got all the info I needed there for my Rex, but it was a long time ago. If the info is no longer there, let me know I may still have the sheets.
Old Feb 24, 2004 | 05:26 PM
New User
Sorry, I've been real busy.
This is a wiring diagram for the ECU Pr3
A is the 18pin white plug
B is the 20pin black plug
C is the 16pin black plug
tap 12volt sorce (a25)
tap ICM ignition control module for RPM (a21)
feed vtec solenoid valve through svfc vtec (a4)
feed vehicle speed sensor through svfc vtec (b10)
cut vtec pressure switch to ECM svfc vtec supplies this to ECM
I know it's a little confusing.
here are some other good links
http://b16a.honda-perf.org/theswap.html
brian hasty from hasport
kelley grusin at hondahaven
http://www.honda-perf.org
here is some more wiring info I found
from the vafc (green wire tap rpm signal to ecu)
from the vafc red wire tap ignition source
from the vafc light blue connect to speed sensor
from the vafc blue connect vtec signal
the vtm line on the ecu is cut and taped off
Hope this helped a little.
z6hatch
Jun 30, 2004 12:16 PM
Frederz
Feb 29, 2004 10:01 PM
wgs0023
Feb 26, 2004 03:49 AM
egturbo
Nov 21, 2003 02:32 PM
Turbo Powa
14
Apr 8, 2003 08:48 AM
