How hard to convert whole car to obd1?
Old Feb 22, 2004 | 06:34 PM
fatrhino's Avatar
Default How hard to convert whole car to obd1?
My friend is doing a LS swap into his 91 Civic STD. The engine is from a 93 LS. The engine is already in, and now it is time to wire. He has the entire harness from the Integra and would like to replace the entire harness in the Civic with the one from the LS. Is this a good idea? Is it too much work? Has anyone done this?
Old Feb 22, 2004 | 07:35 PM
kid-honda's Avatar
He can easily keep it OBD 0 with 90/91 LS ecu dist.
Why go to OBD? does he have emmissions?
If you have to convert its not that hard and can be made real easy with a conversion harness.
Old Feb 22, 2004 | 07:36 PM
kid-honda's Avatar
Always use your stock harness, it will make life easy.
Old Feb 22, 2004 | 07:42 PM
I Gotta Question's Avatar
Default Re: How hard to convert whole car to obd1? (fatrhino)
yes you can do it I did it twice and my car will pass smog in cali with this wiring, none of that ghetto rig harness stuff, obd1 is better anyways, if you wanna know how to do it just email me and i'll hook you up with what needs to be done.
Old Feb 22, 2004 | 07:49 PM
acydphryck's Avatar
converting to OBD1 was expensive for me... but well worth it.
Old Feb 22, 2004 | 07:57 PM
goforbroke's Avatar
MEAT PATTY
Default Re: How hard to convert whole car to obd1? (acydphryck)
I'm going to be converting my 88std model to obd1 soon. And the parts that you "I think" are
1. jumper harness from obd0 to obd1
2. obd1 distrubutor
3. obd1 wiring harness
4. probably some other stuff but I don't remember right now, ACYDPHRYCK probably knows considering he already did it already.
Old Feb 22, 2004 | 08:42 PM
Default Re: How hard to convert whole car to obd1? (goforbroke)
i think the engine he has is already obd1, so if that is true all hes gonna need is the main part of the wiring harness, the part that connects to the ecu and too the engine harness, you know the three grey plugs, and you will need the little gray 2 wire plug on the drivers side along with the 14 wire plug that is over there too and you will need the obd1 ecu and you will need some solder and electric tape
Old Feb 23, 2004 | 01:32 AM
StorminMatt's Avatar
Default Re: (kid-honda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kid-honda &raquo;</TD></TR><TR><TD CLASS="quote">He can easily keep it OBD 0 with 90/91 LS ecu dist.
If you have to convert its not that hard and can be made real easy with a conversion harness.</TD></TR></TABLE>
Yes, but (1) The 1992-1993 ECU has better fuel maps for the motor, (2) the 1992-1993 ECU will give better fuel economy, and (3) he probably already has the 1992-1993 ECU. Converting to the 1990-1991 stuff requires the purchase of not only the ECU but also the distributer.
stealthmodeSI
19
Feb 20, 2020 04:06 PM
lejeaune
Apr 21, 2010 09:31 AM
bobbyisking
Jul 7, 2008 09:22 AM
apice
Mar 19, 2008 03:35 PM
WrongWD
Feb 10, 2005 01:06 AM
