i'm missing the studs on the block to help hold up the header...where can i buy these?
Old Feb 22, 2004 | 07:07 AM
Project_ED8's Avatar
Default i'm missing the studs on the block to help hold up the header...where can i buy these?
i'm currently doing a d16a6 swap into my hf and the motor i bought only had 2 studs on the block that help hold up the header and the oter 7 or so are missing. do they sell these at like a auto parts store or dealership or is it if they are gone your screwed? ok thanks for the help.
Old Feb 22, 2004 | 07:25 AM
2point2's Avatar
Default Re: i'm missing the studs on the block to help hold up the header...where can i buy these? (Project_
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Project_ED8 &raquo;</TD></TR><TR><TD CLASS="quote">i'm currently doing a d16a6 swap into my hf and the motor i bought only had 2 studs on the block that help hold up the header and the oter 7 or so are missing. do they sell these at like a auto parts store or dealership or is it if they are gone your screwed? ok thanks for the help.</TD></TR></TABLE>
You can find all the studs you can ask for at the auto-wreckers.. take the studs off of a car that doesn't have a header - use vise grips.. and get the locking nuts off of a car that still has the header.
good luck.
Old Feb 22, 2004 | 07:40 AM
ek_99_SiR's Avatar
i dont know about using vise grips, i would u the right tool... youll run the risk of stripping it if u dont
Old Feb 22, 2004 | 10:58 AM
do you happen to know the tool they use and where i could possibly find it or just the name of it? thanks
Old Feb 22, 2004 | 11:17 AM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Default Re: (Project_ED8)
A stud remover is the name of the tool..
Most places carry them..Sears for example:
http://www.sears.com/sr/javasr...58000
Old Feb 22, 2004 | 11:20 AM
ghettocrxsi's Avatar
Default Re: (88DXCRX)
Or use two nuts and tighen them against eachother on the stud. THen unloosen the nut closest to the head and it should pull the stuf out.
Old Feb 22, 2004 | 11:23 AM
2point2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1.6i-16zc &raquo;</TD></TR><TR><TD CLASS="quote">i dont know about using vise grips, i would u the right tool... youll run the risk of stripping it if u dont</TD></TR></TABLE>
There is a part on the stud where there is no thread.. small vice grips and a an open palm tap should do it. So what if there is some teeth marks on the shaft part. I like buying tools.. but i haven't had to buy a stud removal tool for my project yet.
It's a slightly gehto way of doing it... hehe.. 8)
Old Feb 22, 2004 | 11:32 AM
2point2's Avatar
fo life!
Old Feb 22, 2004 | 11:47 AM
88DXCRX's Avatar
The two nut thing as mentioned above can also work..
And nothing against Vise-grips 2.2
I have several pairs of them myself..
Old Feb 22, 2004 | 12:26 PM
crxY-49's Avatar
make life easy and bring one of your studs down to autozone. they have em.
Old Feb 22, 2004 | 03:59 PM
2point2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88DXCRX &raquo;</TD></TR><TR><TD CLASS="quote">
Nice.
Old Feb 22, 2004 | 07:13 PM
SlowSpoolin1.6SOHC's Avatar
i used the 2 nut method worked for me
1200 Hobos
Oct 15, 2008 10:08 PM
J-Spot
41
Aug 7, 2007 02:47 PM
smalls
Jul 18, 2006 05:46 PM
rmcdaniels
13
Aug 13, 2005 07:22 PM
Milano97
Jun 17, 2002 12:45 PM
