b18a in a 94+ teg?
Old Feb 21, 2004 | 05:20 PM
Si Integra's Avatar
Default b18a in a 94+ teg?
Has anyone on here put a b18a in a 94+ teg?
At least the short block?
What if any where the differences or changes that had to be made?
aWhere there any extra obd I, II sensors that did not have a place to go?
Old Feb 21, 2004 | 05:44 PM
FlaN.'s Avatar
why would you want to do that?
Old Feb 21, 2004 | 05:48 PM
Si Integra's Avatar
Default Re: (theJUMPoff)
curious
Old Feb 21, 2004 | 06:59 PM
Rod.'s Avatar
no difference
Old Feb 21, 2004 | 07:39 PM
94B18B1Teg's Avatar
Default Re: b18a in a 94+ teg? (Si Integra)
the B18A is obd0 I believe
and the bottom end between the B18A and B18B are the same...I think its all in the flow of the head and intake manifold that makes the difference...and of course the obd0 and obd1...some sensors and I think the B18A is also a cable tranny, not a hydro like the B18B's....
Old Feb 21, 2004 | 08:04 PM
xSCTYGx's Avatar
Default Re: b18a in a 94+ teg? (94B18B1Teg)
90-91 b18a is obd0 at around 130hp...92-93 b18a1 is obd1 at around 140hp
putting a 90-91 b18a would be pointless dropping into a 94+ teg...however the 92-93 b18a1 will be basically the same thing..
Old Feb 21, 2004 | 10:48 PM
mr.beeks's Avatar
Default Re: b18a in a 94+ teg? (2Gen91Teg)
blah blah blah!!
just put it in and enjoy...
basically just match the sensors on the block plus mounts and call it a day..
Old Feb 21, 2004 | 11:13 PM
tegasaurus's Avatar
Default Re: b18a in a 94+ teg? (mr.beeks)
i have a b18a short block in my car right now... sucker is the exact same as a b18a.
-ryan
Old Feb 21, 2004 | 11:24 PM
mr.beeks's Avatar
Default Re: b18a in a 94+ teg? (tegasaurus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegasaurus &raquo;</TD></TR><TR><TD CLASS="quote">i have a b18a short block in my car right now... sucker is the exact same as a b18a.
-ryan</TD></TR></TABLE>
b18a and b18a...
Old Feb 21, 2004 | 11:39 PM
tegasaurus's Avatar
eph me... last part should be b18b
Old Feb 22, 2004 | 05:45 AM
Si Integra's Avatar
I suppose I would have had a lot less info re-introdused that I already knew if I had informed everyone that the head I am using is from a b18b and is fully ported with crower internals and b18b cams. The intae manifold was also extrude honed and the turbo manifold has ben port matched to the exhaust side of the head. I am only using the bare block and cran, the rods, bearings, seals, pistons, water/oil pump will be replaced.
I am asking because the blocks have a quite a difference in priceand I have several b18a blocks. What water pump and oil pump should I use?
Thans for all the help.
Old Feb 22, 2004 | 06:10 AM
arw321's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2Gen91Teg &raquo;</TD></TR><TR><TD CLASS="quote">90-91 b18a is obd0 at around 130hp...92-93 b18a1 is obd1 at around 140hp
putting a 90-91 b18a would be pointless dropping into a 94+ teg...however the 92-93 b18a1 will be basically the same thing..</TD></TR></TABLE>
All non-vtec 90-93 b18 motors are stamped B18A1.
Old Feb 22, 2004 | 08:23 AM
Si Integra's Avatar
Default Re: b18a in a 94+ teg? (arw321)
Yeah, the stampings do not matter to me, it is the function the electronics will have or no thave...
D1andOnly
Nov 26, 2005 07:21 AM
ShagPower
Sep 2, 2005 07:29 AM
RocketEG6
Mar 1, 2005 08:29 PM
Tammy_EP3
Oct 16, 2003 02:12 PM
