What final drive for 1/4 mile?
Old Feb 21, 2004 | 06:24 AM
itr_18's Avatar
Default What final drive for 1/4 mile?
What final drive that is possible to "buy" is the best for 200 whp all motor itr for 1/4 mile?
Any ideas, comments, web sites?
Old Feb 21, 2004 | 06:32 AM
Alberto's Avatar
Default Re: What final drive for 1/4 mile? (itr_18)
http://www.a-t-s-usa.com/ats-p...shtml
Old Feb 21, 2004 | 07:51 AM
jond's Avatar
I may be wrong, but I think any aftermarket final drive is going to slow you down in the 1/4.
Old Feb 21, 2004 | 07:54 AM
Tommy_Gunns's Avatar
Default Re: What final drive for 1/4 mile? (jond)
You are wrong.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jond &raquo;</TD></TR><TR><TD CLASS="quote">I may be wrong, but I think any aftermarket final drive is going to slow you down in the 1/4.
Old Feb 21, 2004 | 08:03 AM
jond's Avatar
Default Re: What final drive for 1/4 mile? (Tommy_Gunns)
You wont have to shift into 5th before the trap?
Old Feb 21, 2004 | 08:23 AM
DsITR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jond &raquo;</TD></TR><TR><TD CLASS="quote">You wont have to shift into 5th before the trap?
most likely not..
Everyone on the board seems to refer to this one post, where someone had an ITR tranny in a EG, w/the ATS FD. He did some runs, conclude the ATS was slower in the 1/4.
No one considered that the OD of his tire has smaller than the ITR tire, so he effectivley geared his car lower than OEM *2times*.
*He* was shifting into 5th. In a ITR w/OEM Size tire that is most likely not going to happen.
If you guys wanna check it out yourself, here is a gear calc you can mess w/
http://reverendsgarage.net/ind...r.php
Old Feb 21, 2004 | 08:28 AM
jond's Avatar
Default Re: What final drive for 1/4 mile? (DsR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DsR &raquo;</TD></TR><TR><TD CLASS="quote">
most likely not..
http://reverendsgarage.net/ind...r.php</TD></TR></TABLE>
Gotcha.
Old Feb 21, 2004 | 09:25 AM
itr_18's Avatar
Now I have 4.7X (EDM=JDM tranny) with shorter 4th and 5th gear (4 was so weak until this mod). Now I finish 1/4 mile on 4th gear on 8700 rpm. But is there something better for me for 1/4 than 4.7? 4.9 would be better or not?
Old Feb 21, 2004 | 09:31 AM
itr-j's Avatar
Default Re: (itr_18)
5.1
Old Feb 21, 2004 | 10:32 AM
DsITR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr_18 &raquo;</TD></TR><TR><TD CLASS="quote">Now I have 4.7X (EDM=JDM tranny) with shorter 4th and 5th gear (4 was so weak until this mod). Now I finish 1/4 mile on 4th gear on 8700 rpm. But is there something better for me for 1/4 than 4.7? 4.9 would be better or not?</TD></TR></TABLE>
If that's the case 4.9 may be too short.. it sounds like you would be shifting into 5th right @the end. (maybe jond is right)
4.9 would net better accleration for the majority of distances.. But if you are only after 1/4mile, it's probobly best to leave it alone.
not to mention you save yourself $750
Modified by DsR at 12:46 PM 2/21/2004
Old Feb 21, 2004 | 11:31 AM
Black R's Avatar
25 Year Member
..... just raise your rev limiter to 9200 and run the 4.9.
If it's good enough for erick aguilar, it's good enough for me!
Old Feb 21, 2004 | 06:05 PM
itr_18's Avatar
Default Re: (Black R)
Its already 9100 and Im going in 9400-9500 on new cams. SO? 4.9?
Old Feb 21, 2004 | 06:27 PM
Eric R's Avatar
Why you get a higher final drive for? To get more acceleration! So, given the right conditions you should be quicker in the 1/4 mile.
Old Feb 21, 2004 | 06:59 PM
itr_18's Avatar
thx for answers!
mugenintegra16
Honda S2000
18
Aug 28, 2008 11:58 AM
Solo2Vtec
Honda Civic (2006 - 2015)
13
Mar 23, 2007 10:50 AM
bootlegtrader
Aug 22, 2005 04:10 AM
zentraedityper
Dec 17, 2003 07:15 PM
BenB
Jun 9, 2003 01:28 PM
