Wet Sanding??
Old Feb 20, 2004 | 07:51 AM
Mrfeee1's Avatar
Default Wet Sanding??
Question. If you wet sand something (plastic) completely clear with fine enough grit. and polish it. is it possible to get rid of scratches and restore its (glass like) transparency.
Old Feb 20, 2004 | 08:13 AM
ek_99_SiR's Avatar
Default Re: Wet Sanding?? (Mrfeee1)
yes and no. what kind of plastic is it? and what grit sand paper? u might wanna look into a polishing compound or rubbing compound
Old Feb 20, 2004 | 08:26 AM
redlinetuning's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mrfeee1 &raquo;</TD></TR><TR><TD CLASS="quote">Question. If you wet sand something (plastic) completely clear with fine enough grit. and polish it. is it possible to get rid of scratches and restore its (glass like) transparency.</TD></TR></TABLE>
i'm looking into doing the same to my rears.. i've heard people using 2000 grit with a lot of water.. and finish off with some 3m polishing/rubbing compound that should do the job..
Old Feb 20, 2004 | 12:30 PM
RedTegLS's Avatar
Default Re: Wet Sanding?? (redlinetuning)
Tell me your not referring to your tailights!
Old Feb 20, 2004 | 01:07 PM
FlySi's Avatar
Default Re: Wet Sanding?? (RedTegLS)
yes you are looking for a product called "gel-gloss" they sell it at home depot. just work your way up on the automotive sand papers then use either a buffer or a drill with a buffing pad in it and use the gel-gloss.. it can take some time, the longer you spend the better it will look. i used this product in my robotics classes, it gives all the fictures made from plexiglas a nice clean look
Old Feb 20, 2004 | 01:34 PM
B U N M A N G O's Avatar
yes... https://honda-tech.com/zerothread?id=574874#6101692
I just used rubbing compound on that, but it's the same concept. Always work from the least agressive method possible on up...
I've used down to 1000 grit on headlights before... followed up by 2000 grit, rubbing compound, and then plastic polish. Lights came out as good as new
Old Feb 20, 2004 | 01:39 PM
^jefs0ng's Avatar
Banned
^ that man knows what he's talking bout.
Timmyflys
Paint and Body
Oct 17, 2007 10:42 AM
LeArN2LiVe
Paint and Body
Jun 27, 2007 01:32 PM
corrupt0r
Welding / Fabrication
Apr 17, 2007 10:22 PM
huge230
May 29, 2006 01:02 PM
Ti3d in
Feb 16, 2004 08:12 AM
