Spraying technique question
Old Jun 27, 2007 | 12:48 PM
LeArN2LiVe's Avatar
Default Spraying technique question
Modified by LeArN2LiVe at 12:16 AM 9/12/2007
Old Jun 27, 2007 | 01:32 PM
WihaSi's Avatar
Default Re: Spraying technique question (LeArN2LiVe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LeArN2LiVe &raquo;</TD></TR><TR><TD CLASS="quote">My question is how exactly should I spray the paint? I know that multiple thin coats are better than a single thick coat but how do I avoid drips? And should I spray side to side and slowly move down or should I spray down vertically? Thanks in advance! </TD></TR></TABLE>
You kind of answered your own question. You want to put 2-3 medium coats of color on to assure your side skirts have full coverage. By not spraying it on wet is how you will avoid running the base coat. You can apply the clear coat a bit heavier, and I would do 2 coats of that.
As for sanding the skirts you can get away with 320 grit and skip the 400 wet if you want, or just do the 400 wet. Then apply 2-3 coats of primer (2 is usually enough). When painting the skirts, I would just put them on a horse or a bumper stand and spray them horizontally.
EvenStar
Paint and Body
20
Sep 5, 2008 11:24 PM
reactone
Paint and Body
Nov 16, 2007 04:03 PM
lamboextreme
Feb 5, 2007 09:51 PM
jake15348
Jul 22, 2005 01:41 PM
