LS vtec timing belt?
Its best to use a factory honda belt. If you are useing a B16a head you can use the LS timing belt,but if you use a GSR head you have to use a gsr belt. You can also use the same water pump (ls) or B16a pump.
If you're using a b16a head and the factory LS water pump, you can just use the LS timing belt. If you use a GSR head (or even a b16a head) with a GSR water pump you're going to have to shell out the extra money for the GSR timing belt.
I use the LS, it's cheaper
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jedubz »</TD></TR><TR><TD CLASS="quote">If you're using a b16a head and the factory LS water pump, you can just use the LS timing belt. If you use a GSR head (or even a b16a head) with a GSR water pump you're going to have to shell out the extra money for the GSR timing belt.
) </TD></TR></TABLE>
Can you reuse the same timing belt or will I have to buy a new one?
) </TD></TR></TABLE>Can you reuse the same timing belt or will I have to buy a new one?
It depends. Of course you can it's not like it's going to be any different than taking a timing belt off an LS and putting it back on an LS... it's just a matter of if you think it is in good enough condition to take the revs.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jedubz »</TD></TR><TR><TD CLASS="quote">It depends. Of course you can it's not like it's going to be any different than taking a timing belt off an LS and putting it back on an LS... it's just a matter of if you think it is in good enough condition to take the revs. </TD></TR></TABLE>
Word. And since they cost 45 dollars, it won't hurt too much to get one just to be safe.
turbo_b16_ex
Oct 4, 2005 11:06 AM
B18 CYA
May 11, 2005 03:11 PM
wade
Jun 20, 2004 02:21 PM
