Front motor mount removal? (PITA)
Old Feb 20, 2004 | 06:07 AM
vabchaccord's Avatar
Default Front motor mount removal? (PITA)
Alright, this is a pretty basic question, but the through bolt nut that holds my front motor mount to the bracket that attaches to the engine is stuck. It is in a hard area to get to, a small space between the engine and the radiator, maybe a couple of inches. Any suggestion on how to free-up that bolt? I have been leaning on it with a ratchet and pipe extension, but I can't get too much freedom of movement in there and it just won't budge. Any suggestions would be great. 1997 Accord EX 4 cylinder sedan.
Old Feb 20, 2004 | 06:52 AM
TouringAccord's Avatar
H-T Order of Merit
Default Re: Front motor mount removal? (vabchaccord)
use some PB Blaster and a long extension to bring the rachet out of the engine bay and give you more room.
Old Feb 20, 2004 | 06:53 AM
Default Re: Front motor mount removal? (TouringAccord)
This is the transverse bolt that runs left to right as you look down in to the engine bay, parallel to the ground, it doesn't stick up vertically.
Old Feb 20, 2004 | 07:13 AM
H-T Order of Merit
upps...sorry. get a steel bar and slide it over the end of the rachet to give you more leverage.
Old Feb 20, 2004 | 07:38 AM
already tried that, not enough space to break it free.
Old Feb 20, 2004 | 08:00 AM
Luisito825's Avatar
longer socket?
Old Feb 20, 2004 | 08:06 AM
Default Re: Front motor mount removal? (buss)
Not so much the size of the socket, I just need something that can get down there in that confined space and break it free, then I can just use a ratchet to get it off the rest of the way. Anyone know if these bolts slip out, after I 've taken the nut off, fairly easily, or...
Old Feb 20, 2004 | 10:30 AM
James's Avatar
I dont know if it applies to you but sometimes you need to take out other parts in order to take out that part - maybe you can check and see if there is any part you need to remove to give you more room to loosen the bolt/nut?
i know it can be pain in butt but sometimes you will find it a lot easier doing this way.
Old Feb 20, 2004 | 11:14 AM
H-T Order of Merit
I can't remember if the nut is welded to the bracket or not, might want to make sure.
I know mine wasn't that hard to get off when I pulled the motor last winter.
Old Feb 20, 2004 | 11:19 AM
v4lu3s's Avatar
RTFM
uses a wrench or get a better ratchet, it is most likely that your ratchet needs more room too work since most cheaper ones need more space to actually ratchet compared to higher dollar tools.
Old Feb 20, 2004 | 11:39 AM
Elvis1977's Avatar
slightly raise the engine with a floor jack to relieve stress on mount, and use a universal elbow.
Old Feb 20, 2004 | 11:50 AM
James's Avatar
thought this diagram might help you - it looks like that the nut is welded onto the bracket.
http://www.hondaautomotivepart...84%29
Old Feb 20, 2004 | 02:35 PM
H-T Order of Merit
Default Re: Front motor mount removal? (James)
yeah, thats what I was talking about. I thought it was welded to the bracket itself.
Old Feb 20, 2004 | 03:29 PM
h224u's Avatar
Hey u have to get to it from the bottom. I just did this last night on my own car but im a tech for a bmw dealer so i had a lift, but if u dont have a lift just jack it up and u can get it from the bottom. Just make sure u try to losen the right side of the motor mount not the drivers side becouse its weldded.
ok have fun
Old Feb 20, 2004 | 05:07 PM
Eddiebx's Avatar
its a pain in the *** buy u can unbolt the radiator and lift it up a bit to give you more room, thats what i had to do.
Old Feb 21, 2004 | 12:21 PM
H-T Order of Merit
Default Re: Front motor mount removal? (h224u)
I don't think it's easier from the bottom. I know I haven't done mine in a year but I think it's much easier to get it from the top. I think from the bottom you'll have less room. I don't know, thats just my $.02
Old Feb 21, 2004 | 12:43 PM
97F22B2's Avatar
its not thta hard folks, just removed mine for my turbo so i could modify it and all i used was a ratchet and a stell pole so i could get more leverage and had another socket on the ohter side braced against somehting to break it all loose.
roscomojo
Honda Civic (2001 - 2005)
Apr 17, 2017 07:36 PM
Sean1992
Honda Civic (2006 - 2015)
Feb 2, 2017 02:25 AM
B18b Axles
Jun 22, 2012 08:19 AM
216.226.142.95:27016
Jun 29, 2003 02:27 PM
maxxdout
Jan 2, 2003 12:01 PM
