Quick Question???
Old Feb 19, 2004 | 07:23 PM
93EH6
Guest
Posts: n/a
Default Quick Question???
I have a 92 civic cx and the steering wheel sits to high for me and i was wondering if there is a way to lower it about an inch or so??
thanks for the help
Old Feb 19, 2004 | 07:25 PM
BauleyCivic's Avatar
Risky Business
Default Re: Quick Question??? (93EH6)
There should be a black handle under the steering column on the left, pull it down, move your steering wheel accordingly, then push the lever back up.
Old Feb 19, 2004 | 07:26 PM
Jimmy's Avatar
Global Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93EH6 &raquo;</TD></TR><TR><TD CLASS="quote">I have a 92 civic cx and the steering wheel sits to high for me and i was wondering if there is a way to lower it about an inch or so??
thanks for the help</TD></TR></TABLE>
As far as i know the cx didnt come with tilt steering so your screwed.
Not 100% sure though
Old Feb 19, 2004 | 07:27 PM
MrIllegalX's Avatar
Default Re: Quick Question??? (Usdmdc2)
probably don't have tilt steering. nothing you can do about it.
Old Feb 19, 2004 | 07:28 PM
Ricey McRicerton's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Usdmdc2 &raquo;</TD></TR><TR><TD CLASS="quote">
I actually think they did. My friend had a CX hatch with it I think.
Honestly I'm not 100%. Check it like Bauley said.
SLR SKiLLZ's Avatar
well if i came it came equiped with it, it would be located on the left towards the back bottom, pull the lever and raise or lower the steering wheel until its comfortable for u
Old Feb 19, 2004 | 07:29 PM
Risky Business
Default Re: Quick Question??? (SLR SKiLLZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SLR SKiLLZ &raquo;</TD></TR><TR><TD CLASS="quote">well if i came it came equiped with it, it would be located on the left towards the back bottom, pull the lever and raise or lower the steering wheel until its comfortable for u</TD></TR></TABLE>
Whoa! Thanks for bringing this information to the table!
Old Feb 19, 2004 | 07:31 PM
93EH6
Guest
Posts: n/a
Nope i don't have tilt wheel but i was wondering (just a shot in the dark) if there were bolts you could space out or somthin cause my sparco wheel sits right in front of the speedometer
Old Feb 19, 2004 | 07:32 PM
Risky Business
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93EH6 &raquo;</TD></TR><TR><TD CLASS="quote">Nope i don't have tilt wheel but i was wondering (just a shot in the dark) if there were bolts you could space out or somthin cause my sparco wheel sits right in front of the speedometer</TD></TR></TABLE>
Take a hammer and hit the steering column until it breaks free. Then adjust it to where you want it, then get some coat hangers and hang it from the ceiling to keep it from bobbing back and forth.
In all seriousness, you're SOL
Old Feb 19, 2004 | 07:35 PM
street dreams's Avatar
From: chillin in that city called queen creek, but homes the atl
Default Re: Quick Question??? (BauleyCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic &raquo;</TD></TR><TR><TD CLASS="quote">
In all seriousness, you're SOL </TD></TR></TABLE>
i like this answer
Old Feb 19, 2004 | 07:56 PM
93EH6
Guest
Posts: n/a
whats that all about
Old Feb 19, 2004 | 08:04 PM
Risky Business
whats that all about</TD></TR></TABLE>
You asked if you could adjust your steering column, and you have a non-adjustable steering column. So, after 10 minutes in deep thought I concluded that it isn't possible to adjust your non adjustable steering column and that you are in fact **** outta luck.
Old Feb 19, 2004 | 08:12 PM
93EH6
Guest
Posts: n/a
You asked if you could adjust your steering column, and you have a non-adjustable steering column. So, after 10 minutes in deep thought I concluded that it isn't possible to adjust your non adjustable steering column and that you are in fact **** outta luck. </TD></TR></TABLE>
Oh ok i never heard the whole SOL thing before i thought you were talking about my old car and it made no sence wheres the little hammer thing when you need it
D21X
12
Mar 5, 2010 07:22 AM
InfiniteS2K
Honda S2000
17
Sep 6, 2007 09:03 PM
mRek9R
Suspension & Brakes
28
Jul 2, 2006 08:49 PM
Mikey3000
May 9, 2006 03:58 PM
stockcivic103
Mar 20, 2006 09:43 PM
