which harness conversion?
Your confused. You DONT need a harness conversion
The OBD2(2001 engine harness) will be a direct plug into you OBD1(car chassis harness). The only thing that you will need to do it get yourself a OBD1 ecu. It will plug directly into the harness that is plugged into your current ecu.
