59300......adjusting the valves???
Old Feb 19, 2004 | 03:38 PM
EGinNY's Avatar
Default 59300......adjusting the valves???
Im going to be installing the zex 59300 w/ aem adj. cam gear into my d16z6, I was wondering if anyone knew what to set the valves to....i dont have the sticker under the hood or a helms
TY in advance
EDIT: tried searching
Modified by EGinNY at 7:54 PM 2/19/2004
Old Feb 19, 2004 | 03:45 PM
ARIZONA's Avatar
Default Re: 59300......adjusting the valves??? (EGinNY)
Off the top of my head.... I believe INtake is .007 and EXhaust is .009
Please correct if I am mistaken
Old Feb 19, 2004 | 04:07 PM
SOHC_MShue's Avatar
Default Re: 59300......adjusting the valves??? (ARIZONA)
yes I have this cam in my y8 and .007 intake and .009 exhaust is correct.
Old Feb 19, 2004 | 04:08 PM
infinatenexus's Avatar
.05, and .06 for me
Old Feb 19, 2004 | 04:20 PM
SOHC_MShue's Avatar
Default Re: (infinatenexus)
did you adjust them like that just so it would quiet the cam down? Because I know for the specs of the cam on the zex website it sais .007 and .009
I went untill it was quiet
Old Feb 19, 2004 | 05:07 PM
drewbie's Avatar
can someone do a DIY on valve adjustment? its prolly worth saving 100 bucks
Old Feb 19, 2004 | 05:09 PM
zseeanz's Avatar
Default Re: 59300......adjusting the valves??? (SOHC_MShue)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue &raquo;</TD></TR><TR><TD CLASS="quote">yes I have this cam in my y8 and .007 intake and .009 exhaust is correct. </TD></TR></TABLE>
Old Feb 19, 2004 | 05:32 PM
ARIZONA's Avatar
Default Re: (Mr. Teal)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. Teal &raquo;</TD></TR><TR><TD CLASS="quote">can someone do a DIY on valve adjustment? its prolly worth saving 100 bucks
FOR D SERIES...
Remove Valve Cover after putting motor at TDC (compression stroke tisk tisk!)
start with #1 cyl valves... Do Intake first, then Exhaust...
You will first loosen the retaining nut (10mm) place feeler gauge of desired size under the adjustable flat head stud in the 10mm nut and tighten or loosen until a "slight drag" is achieved. Hold stud bolt in place with the flathead while tightening 10mm nut. Recheck for "slight drag". When satisfied continue with remaining intake valve then exhaust valves for #1 cylinder order....
Continue process in the firing order of the engine. What you will do when complete with #1 is move the crank counterclockwise manually until the cam sprocket completes 90 degree rotation from it's "UP" position.
So, with the sprocket at the 3 o'clock position, you adjust cyl 3
6.........................................cyl 4
9.........................................cyl 2
In that order.
If you miss your mark by turning the crank too far, DO NOT go clockwise to adjust, you must turn it COUNTERclockwise to the TDC (white mark) and around one more time (so 2 revolution to your intended mark) If you go around only once, it is at the exhaust stroke and will be wrong
Hope that helps
Old Feb 19, 2004 | 05:42 PM
Dr. Gonzo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by infinatenexus &raquo;</TD></TR><TR><TD CLASS="quote">I went untill it was quiet</TD></TR></TABLE>
I had that cam(z6), did the valves to the specs on the website and it was still noisy as f***.
Old Feb 19, 2004 | 06:14 PM
SOHC_MShue's Avatar
Default Re: (benji)
yes it is a very noisy cam because of the high lift.
Old Feb 20, 2004 | 04:16 AM
Default Re: (SOHC_MShue)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue &raquo;</TD></TR><TR><TD CLASS="quote">yes it is a very noisy cam because of the high lift.</TD></TR></TABLE>
well your 1/2 right. Because its a regrind the ramp angle is extreamly steep.. thats what caused the noise.
Old Feb 20, 2004 | 05:32 AM
SOHC_MShue's Avatar
i thought they made them from blanks?
Old Feb 20, 2004 | 10:34 AM
nub's Avatar
nub
new cores, not regrinds. went .07-.09 originally and eventually went .05-.06 to qiuet it down.
TheToaster
Nov 28, 2011 11:44 AM
Pfieff
Jan 21, 2009 12:14 PM
91redteg
Oct 14, 2007 04:30 PM
SLOAZZ95
Mar 2, 2004 03:58 AM
Comptech98GSR
Aug 1, 2002 02:28 PM
