LSD - questions
Old Feb 19, 2004 | 02:46 PM
ek4hatch's Avatar
Default LSD???
what sup all
i have a quick question, i have a 96 hb with a gsr motor but i don't have lsd
so i am getting this 98 usdm itr lsd (not tranny just lsd)
what the difference to don't have lsd??
and what the difference to have it??
i iam asking u cuzz all of u guys have an itr cars with lsd???
so how it feels to have lsd??
how would help me to have lsd in my motor??
any comments are welcome thanks!!
Old Feb 19, 2004 | 03:59 PM
SleepnCiViC's Avatar
cut down on tourqe steer dramatically, and will give better launches. and people say its better round turns, but i never noticed a difference, but im sure to people who are serious into autocross and all can tell.
Old Feb 19, 2004 | 04:08 PM
DsITR's Avatar
Default Re: LSD??? (ek4hatch)
The differential has three jobs:
-To aim the engine power at the wheels
-To act as the final gear reduction in the vehicle, slowing the rotational speed of the transmission one final time before it hits the wheels
-To transmit the power to the wheels while allowing them to rotate at different speeds
http://auto.howstuffworks.com/differential.htm
read and learn grasshoppa!
Old Feb 19, 2004 | 10:10 PM
ek4hatch's Avatar
Default Re: LSD??? (DsR)
thanks guys
also it would help on my 60 foot right??
Old Feb 19, 2004 | 10:14 PM
baonest's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek4hatch &raquo;</TD></TR><TR><TD CLASS="quote">thanks guys
also it would help on my 60 foot right??</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">and will give better launches.</TD></TR></TABLE>
i dont know, you tell me. it was stated in the posts above
Old Feb 19, 2004 | 10:17 PM
ek4hatch's Avatar
Default Re: LSD??? (baonest)
my bad!!
DsITR's Avatar
sure will...see job #1.
It also distributes power to the wheel w/more traction so you don't do a 1 wheeled burnout
Old Feb 19, 2004 | 10:34 PM
ek4hatch's Avatar
with this lsd and some good cluth what would be my time on a 1/4
well if anyones know??
Old Feb 19, 2004 | 10:41 PM
DsITR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek4hatch &raquo;</TD></TR><TR><TD CLASS="quote">with this lsd and some good cluth what would be my time on a 1/4
well if anyones know??</TD></TR></TABLE>
there is really no way to tell...I guess we could guesstamate.
Your ? is probobly better asked in the drag racing forum.
Old Feb 20, 2004 | 04:42 AM
Bbasso's Avatar
how can we tell, you did not say what power you have how much your car weighs and what type of tires you have (along with many other things)...
Don't bother telling me, I couldn't tell you if you if stated every detail. Just to your local strip and do some runs...
Old Feb 20, 2004 | 08:20 AM
ek4hatch's Avatar
Default Re: LSD??? (Bbasso)
well i was trying to get so help but, my last run was 14.8 with open header and all stock gsr on a 96 hb with street tires!! but i guess open header didn't help cuzz the car was slower why?
so i was thinking with my itr lsd, good clutch and sone slicks what should i run??
by the way whats an all stock itr runs on a 1/4 mile??
Old Feb 20, 2004 | 08:28 AM
DsITR's Avatar
faster.. There is no definate answer, until you run it yourself. Although the Drag Racing Forum could give you a better answer.
assuming your 60ft was less than average, that is where the LSD and slicks would really help.
Old Feb 20, 2004 | 05:06 PM
ek4hatch's Avatar
cool , thanks dude
Old Feb 20, 2004 | 05:26 PM
MyBigNut's Avatar
No more peg-legged burners...
You will definately notice better cornering and higher corner exit speed.
Old Feb 21, 2004 | 09:59 AM
mingchi69's Avatar
I to Smooch Pickle
Default Re: LSD??? (MyBigNut)
this is weird.. but when i had my 12 sec b20 motor, i had a quiafe installed in there.
When I tried to do a burnout with my slicks, i couldnt. It was really hard, and when looking at my video, only 1 wheel was spinning and the other.. kind spinning.
Why is this? was my quaife defective?
Old Feb 21, 2004 | 10:17 AM
DsITR's Avatar
Default Re: LSD??? (mingchi69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mingchi69 &raquo;</TD></TR><TR><TD CLASS="quote">this is weird.. but when i had my 12 sec b20 motor, i had a quiafe installed in there.
Why is this? was my quaife defective? </TD></TR></TABLE>
spinning is not neccessarily a good thing.. it indicates a lack of traction.
Also you were using slicks, to maximize traction so wheelspin should have been minimized.
LSD's are not neccessarily perfect either. They do not transfer power *perfectly* nor do they do so @each millisecond. They just do a far better job.
w/out the quiafe, most likely one wheel would have been spinning @nearly twice the rate of the other.
The fact you were seeing both spinning at all is a good indication it was working.
Old Feb 21, 2004 | 02:08 PM
mingchi69's Avatar
I to Smooch Pickle
then to some degree.. locking your differential so that you're forcing 50-50 on both wheel would actually be more beneficial in drag racing than LSD?? so actually, having a phantom grip would actually be better in drag racing (if it doesnt break) than a normal LSD.
Old Feb 21, 2004 | 03:27 PM
MyBigNut's Avatar
Drag racing... yes.
Anything other than drag racing... no.
Old Feb 21, 2004 | 05:59 PM
T I F O S I's Avatar
just put the **** on your tounge and enjoy it for christsakes!! if you worry this much your done for
NebulousX
Apr 26, 2008 06:28 PM
BB4-Japanpower
Apr 24, 2006 03:52 AM
shadowz
Apr 11, 2004 08:59 AM
jdmcx
Sep 19, 2002 11:02 AM
IntegralGSR
Nov 9, 2001 03:48 AM
