Instructions for changing 1997 integra rotors?
Old Feb 19, 2004 | 08:38 AM
Pimp Joose's Avatar
Default Instructions for changing 1997 integra rotors?
I would like to change my front rotors this weekend and I was hoping someone might be able to give me directions and tips on how to do so.
Thanks!
Pimp J
Old Feb 19, 2004 | 08:45 AM
BolivianDc2's Avatar
Default Re: Instructions for changing 1997 integra rotors? (Pimp Joose)
sign up for http://www.team-integra.net they have a nice article to run you through it
Old Feb 19, 2004 | 08:51 AM
T3mp3sT's Avatar
As stated above, check out TI...
Or, get yourself a Helms Manual
Don't worry its not hard
Old Feb 19, 2004 | 08:58 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Spend $10 on an impact driver from AutoZone BEFORE you start, trust me it will save alot of headaches on those rotor screws.
Old Feb 19, 2004 | 09:40 AM
Tigerzoo's Avatar
Default Re: Instructions for changing 1997 integra rotors? (PatrickGSR94)
remove the break fluid cap.. sometiems helps losen the grip of the pistons when you try to put the rotor back in.
Old Feb 19, 2004 | 10:11 AM
Pimp Joose's Avatar
Thanks guys!
Old Feb 19, 2004 | 01:17 PM
lsracergrl's Avatar
Default Re: (Pimp Joose)
Just a little FYI - my boyfriend and I worked on his rears last weekend and if you round off any parts, it might be a little tricky finding them right away. Good luck!
Old Feb 20, 2004 | 10:52 AM
roadrunner's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">Spend $10 on an impact driver from AutoZone BEFORE you start, trust me it will save alot of headaches on those rotor screws.</TD></TR></TABLE>
I second PatrickGSR94's suggestion -- you will very likely strip at least one of the bolts if you just use a screwdriver...
rufridn
Sep 5, 2005 12:41 PM
daewonder.
Mar 9, 2004 06:48 PM
FredoSP
Oct 1, 2002 07:50 PM
BLITZ
May 9, 2002 10:14 AM
onyx00
Apr 24, 2002 07:33 PM
