b16 crx to b18c
Old Feb 19, 2004 | 07:13 AM
dc2_and_ef's Avatar
Default b16 crx to b18c
i just bought a b18c, and i want to stay with my y1, what else do i need? im going to put hondata, for the ecu.......so what else?
Old Feb 19, 2004 | 09:04 AM
Deetz's Avatar
Crazy Honda Guy
The B18C is a great swap and should work just fine with a Y1 tranny. I take it your going to run OBD1, so all you really need to do is the wire conversion. Also, you may have to consider hood clearance bue to the taller block and what mounts you currently have. I have a Jdm zc hood on mine with a hasport kit which give my engine the room it needs with no rubbing.
Deetz
Old Feb 19, 2004 | 09:51 AM
dc2_and_ef's Avatar
i have the hasport kit also.....i was thinking about swapping heads to the b16, and milling it like 3 thousandths, to kit stock compresion, and i would liek to keep it as easy of an install as possible, so maby keep my pr3 ecu? is this possible?
Old Feb 20, 2004 | 05:03 AM
dc2_and_ef's Avatar
well i found out it is out of a 99 so what is needed to convert it my car to obd 2 or motor to obd 0
Old Feb 20, 2004 | 11:01 AM
Deetz's Avatar
Crazy Honda Guy
I am running a OBD1 PR3 for my setup. Its better to use OBD1 as the tuning options are much better for tuning.
ovsep86
May 3, 2006 11:18 PM
brodequin
Feb 26, 2006 02:16 PM
HT Chaplain
Jan 22, 2006 07:50 AM
Yell88CRXsi
Nov 11, 2003 03:29 PM
BLK99VTECR
Aug 9, 2003 04:54 PM
