Coilover setting for drag racing
Old Feb 18, 2004 | 05:51 PM
Cyphear's Avatar
Default Coilover setting for drag racing
I have a ground control coilovers and i was wondering if it was better to drop low and even all around, or if it was better to do some whack **** like raise the front up (more weight on front tires) or raise the back up?
Old Feb 19, 2004 | 03:46 PM
tegmech's Avatar
Default Re: Coilover setting for drag racing (Cyphear)
Come on guys, any suggestions??? The track opens up in a few weeks and we need to get this stunna in the 12 second club. TIA
Old Feb 20, 2004 | 01:38 AM
96dc2's Avatar
Don't worry about how low you are. Worry about your alignment settings: toe, camber, caster, etc.
Old Feb 20, 2004 | 07:15 AM
vtecvoodoo's Avatar
Future Texas Boy
Just run some higher rates in the rear to keep the car from squatting.
Old Feb 20, 2004 | 07:56 AM
Cyphear's Avatar
Do those little cheap things you insert in your springs between the coils help?
Old Feb 21, 2004 | 05:54 PM
Cyphear's Avatar
Default Re: (Cyphear)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cyphear &raquo;</TD></TR><TR><TD CLASS="quote">Do those little cheap things you insert in your springs between the coils help? </TD></TR></TABLE>
Old Feb 22, 2004 | 09:28 AM
Toretto's Avatar
What cheap things are you talking about? Is it like an insert to keep the spring from compressing?
Old Feb 22, 2004 | 10:39 AM
Cyphear's Avatar
Default Re: (Toretto)
Yeah, its a little wedge shapped thing that goes in between coils to keep the spring from compressing. Heres a terrible drawing: I've seen them at orielys and a local performance shop.
_/|
&lt;_ |
Old Feb 22, 2004 | 06:56 PM
Toretto's Avatar
Have you heard of anyone using them? They might be good for the strip, as long as they dont hurt your springs or shocks.
Old Feb 22, 2004 | 07:23 PM
HR-1320's Avatar
I would run the car as low as possible for a lower center gravity. But you need a camber kit for the front to keep things in check. A good starting point is a 1/2 degree negative so when the front lifts the wheels will straighten . If you don't have 900lb springs for the rear you can double up the bump stops. But don't jack the rear of the car, thats just stupid.
Old Feb 23, 2004 | 12:02 AM
Cyphear's Avatar
Default Re: (2.0Coupe)
Sorry, that "pic" came out terrible. What about jacking up the front of your car? wouldn't that put more weight on the front tires? something just doesn't seem right about that though... ya know? I'll probably pick up a set of those and let you guys know how they do.
Old Feb 23, 2004 | 12:11 AM
So Cal So Boosted's Avatar
what ever you do dont jack the car up in the front....that will only induce weight transfer to the rear
Old Feb 24, 2004 | 09:45 AM
Cyphear's Avatar
But doesn't jacking up the front put more weight on the front tires to start with?
mcmmotorsports
Jul 8, 2006 02:25 PM
cutzmansi
Nov 19, 2004 12:41 PM
AROD
Aug 11, 2004 03:08 PM
EGcivicBoy
18
Apr 3, 2004 09:49 PM
b20civic
Nov 20, 2002 08:00 AM
